Please mind the 307 Electric Failure.
08.05.2020 17:51 # 1
onurtez
Hello friends;
I am a new 307 user, I bought the car on this day. When I first examined it, I did not see much problem, I received an expersis report to the masters.
1. The problem is the mirror settings on the driver's door are stuck (I do not understand if it is actually stuck, I press right, sometimes I donuor press left, it does not freeze, I do it, I want to freeze the bank, but the power is not enough)
2. Automatic light sensor, when I open it manually. The air conditioner display light is decreasing.
The 3rd signal sometimes burns fast. There is a problem with one of the probability bulbs.
4.If I want to manage one of the ten glasses from the seat of the sofor, it hangs sometimes it hurts to the end when I want to close it.
I did not know what is called the 5th road computer setting screen, it is called pixel or pixel.
6. Vehicle closed doors scarce lights Automatically display the gear screen on km indicator and km screen lights do not stop.
7.I hurt the ceiling lamp, it is burning, I close the door, it ends after a few seconds.
8. the horn sometimes rings, sometimes not.
Friends, I did not get up when there was such a failure of electricity. Let me know what my lies are.
Is it reflected to all of them due to 1 thing, or what does it all mean? What should I change and check?
08.05.2020 17:51 # 2
abdullahcolak
good luck, use it without any trouble, insha'Allah.
What is the model year hardware? It's not such big breakdowns, I think it's not daunting, you don't buy zero vehicles, all of which will be done without a lot of cost with a good electrician.
abdullahcolak 2013-08-06 23:40:37
08.05.2020 17:51 # 3
error
All of these are minor problems, so you can be comfortable.
1. I have checked if there is a jam in your engine, but the problem is likely to be cleaned in the mirror control buttons.
2. The digital air conditioner panel has no contact, strongly check
3. Replace both of the signal alarms inside the headlights (you cannot find them at the authorized service, 15 lira at the net)
4. Check if there is a jam in the glass motor or glass "the system thinks the hand is stuck and opens the window again"
5. This is not easy, the screen must be blown or tampered, unfortunately, the screen should change.
6.o not go out immediately wait a moment and try 15 20 min
7. The middle button of the ceiling lamp does some kind of programming, if possible, do not use the middle button
use the ones on the side, it will find its own balance over time.
8. Getting used to pressing on the edges of the horn will not be eliminated, but will improve on time, if it is annoying, apply an oil-free contact spray to the horn's contacts.
the reason for all of this is that the ex-user is either lazy or miss .. most of these are things that come from oxidation.
an electrician can solve them all ...
The humble advice in one means that the vehicle's absence of the old owner is also impaired by the maintenance and controls of the vehicle.
brakes, filters, oils, headlight turn signal brake lights, mechanical lubrication (glass motors mirror motors etc.)
error 2013-08-07 00:37:49
08.05.2020 17:51 # 4
onurtez
thank you for cvplar 2003 1.6 xt premium car cvplar for thanks i relaxed
08.05.2020 17:51 # 5
1. Worn, dirty inside. If you press hard, there will be no problem.
2. No problem, in-car lights are dimmed automatically so that you do not take your eyes.
3. As you said, if one bulb doesn't light up, the other flashes faster than it should be.
4. No problem. You will try to use it.
5. An average of 150 TL is required to replace the 3-line trip computer screen. Available if you search on second-hand selling sites.
6. No problem. it turns off after a while they lock the vehicle.
7. No problem. With the ignition on, press and hold the ceiling light button for 5 seconds. It will be activated again.
8. Go to an electrician. The steering wheel may need to be removed. As far as I understand, there is an oxidation.
Good luck.
08.05.2020 17:51 # 6
ismailkaya
1- If your hand is at first, remove the steering control, open it, clean or have it cleaned. try again
2- I do not know the light of the digital air conditioner screen, but when the headlights turn on, the illumination of the trip computer light decreases. ))
Can be 3-
4-turn 1. I also wrote the dust and the control buttons are multi-functional, for example, hold down closes completely, push, pull, open and close.
5- I guess it should be standing in the sun, if you can read it doesn't matter,
6- 5 minutes later, I think it turns off, even if it does not turn off, it turns off all electrical parts within 30 minutes.
7- Learn control from the ceiling lamp booklet with button function
8- There was an incident that happened to me in the horn. It was not playing in me. I looked at the steering wheel. No problem, but the left front wheel was there.
GOOD LUCK BEWARE AMOSORS MAKE VERY SOUND WHEN IN THE PIT READ YOUR HEADSET READ YOUR BOOKLET THAT MOST NEED TO DO
08.05.2020 17:51 # 7
onurtez
: I do not have a D booklet. If anyone sold the car and did not give the booklet: D can I send it?
08.05.2020 17:51 # 8
error
soft version of booklets of all pejos;
