please let me know
08.05.2020 18:53 # 1
bulut26
My car is more than 2002 206 automatic, original 83 thousand, the car normally does not have any problem in the first departures, after it warms up a little bit, that is, after 5 - 10 km, it heats up to 100 ° C, and stops and does not take the gears in the departures. If the car does not do it, it does not, it does not, and when the gear is not ramped, if the vehicle is ramping, the vehicle slips back or it does not take over this time when it normally takes its own cycle as it is from the brake (normally there is no problem of running back when not heated).
I would be very happy if you can help with this.
08.05.2020 18:53 # 2
pusutr
the transmission will change.
08.05.2020 18:53 # 3
denizci33
Do you get an error from the transmission? is it blinking or something? I don't need to change the gearbox if it doesn't go out; overheating up to 100 normal; trouble; i have 2008 auto; the temperatures are the same. but still look at the fan stage event; it may not come into play. the importance of how you press the gas in automatic is very important; for example, if you go with 100 in 4 gears; If you press hard while pressing like there is an egg under it; vehicle gear drops; The engine screams slightly and accelerates for acceleration. but if you press your foot slightly including take off, the gear changes gradually improve. on slopes, the gear itself drops 1 click; the cycle rises; I live these as well; the vehicle also misses out on extra slopes slightly; but if the slope is not very extra and it still misses; a revision may be required there; the model of the vehicle is low, if it has not been revised before; Unfortunately, our automates want somewhere. but if you change solenoids and oil before revision, you will ride at least 1-2 years more smoothly. solenoid oil vs change keeps about 600-700. revision 2bin-3bin.
08.05.2020 18:53 # 4
bulut26
THANKS A LOT OF THE SNOW LIGHTS THAT ARE THE CVP THAT HAPPENS SO MUCH RATHER WHEN THE UNDERSTAND DOES NOT CONCEPT SO THERE ARE MAKING A DIFFERENCE IN OTHER GEARS, WHEN I HAVE A SENSITIVE:
08.05.2020 18:53 # 5
bulut26
08.05.2020 18:53 # 6
pusutr
On a downhill road, put the car in 1st gear and stop the car. do not apply the handbrake. If the vehicle is walking; transmission.
08.05.2020 18:53 # 7
bulut26
THANK YOU VERY MUCH TODAY ..
08.05.2020 18:53 # 8
denizci33
@@ PUSUTR
I was wondering too. automatic transmission in the vehicle; how to drop the vehicle into 1st gear and stop; Let's try not to harm the brain this time. that is, go to tiptironic and throw it into 1st gear; You say stop the car directly; it didn't make sense to me; this can lead to greater damage.
08.05.2020 18:53 # 9
bulut26
THE VEHICLE IS STOPPING BUT BUT I DID NOT STOP EVERYTHING IF THERE IS HAPPEN :) I WOULD TRY TO REPLACE A RAMP IF I WOULD TRY THAT I WILL NOT CUT THE COPY THAT WAS NOT CUT :)
08.05.2020 18:53 # 10
denizci33
cloud
Do not get locked up after .. I researched thoroughly without automatic gear; this and similar things can cause a lot of extra damage. serious gears of automatic gears can reach up to 4 thousand pounds.
