PLEASE IMMEDIATE HELP
26.02.2021 22:50 # 1
Remef
Hello friends, I am writing from Recep Kocaelin. I am the owner of the 2001 quik. My car stopped suddenly when I was going out at night and after a while I realized that there was no noise from the fuel pump and I would pull the pole + cable from the battery and give it to the pump so that it can be solved until I get home, I probably changed the cable to the indicator to try and then I found the increase of the pump and gave 12v. I tried. I did not immediately notice the incident and the next day realized that my indicator was not showing. I open the contact, the simulated light turns off after 1 second and the needle strikes the end 3 times and returns to the beginning. At the end of the 3rd round, it stays on the bottom and the light does not turn on as if there is no petrol. We were suspicious of the float, whoever I went, said samandira, said samandira, I bought it again, I wonder if the brain needs to be reset etc. no throwing, it just melts and melts and melts to arc the feet and the vehicle goes empty. Waiting for help
27.02.2021 10:40 # 2
GokhaN
Hello Recep
There seems to be a problem in Bsi. Have you ever had it connected to the PC for the fault code
