PLEASE HELP THE NEW 307 110K HIT PROBLEM
08.05.2020 17:00 # 1
meto307
Hello, I just joined your forum. I bought a Peugeot 307 2006 HDI 110K model van. I made about 2000 TL maintenance costs. The triger has changed, the flywheel clutch set has changed. They changed their ears, they changed the swings, they checked the axles, they changed the cartridges. Still the problem is not solved "Cry" & nbsp; & nbsp; & nbsp; friends in the forum using the same tool Do you have such a problem or do you have it or I would be glad if you have all my 307s.
08.05.2020 17:00 # 2
meto307
Is there any other problem besides me? "C
08.05.2020 17:00 # 3
When I say shaking, how could it happen? I could not fully understand. It would be much more understandable if there was a video.
Find a link to my signature ( for new friends who joined us ) please.
koliva 2012-08-24 20:19:28
08.05.2020 17:00 # 4
meto307
When the gas is cut like this, the car is knocked down when the gas is loaded, it can only be felt incomprehensible with the video. like that. bi boslukwar hits the chassis. services, engine is strong, it is dyo, but it came to me, if it is a vote, peugeot engineers have a big mistake.
08.05.2020 17:00 # 5
eray307
I have the same 307d but I don't know why I am not used to use it, I do not pull out the gas and press it. eray307 2012-08-25 10:33:53
08.05.2020 17:00 # 6
goktug
I have the same. I have been using it for 2 years and there is no change. I don't think it's a malfunction either. you shouldn't pay for such little things ..
08.05.2020 17:00 # 7
meto307
I will not wear it anymore, this is in many cars. I will use it this way. thank you for your interest
08.05.2020 17:00 # 8
ramtas
Hello friends, a recommendation related to this issue: adapt the throat butterfly.What you will say about it.After yesterday maintenance, I removed the throat butterfly by squeezing the cleaner from outside without removing it.Then, the master adapted did not disassemble but after the adaptation it was knocked.We repeat the same process. Turn off the ignition completely after 20 seconds after pressing, otherwise the ignition was turned on, or the knockdown of the knockdown lamp in the vehicle, etc .. said that there were malfunctions & nbsp;
08.05.2020 17:00 # 9
ByHack
[QUOTE = ramtas] hello guys, this is a recommendation related to this issue: adapt the throat butterfly.You will say what to do. `` Turn off the ignition completely after 20 seconds after pressing the pedal, or turn off the ignition, or it would say that malfunctions occur in the vehicle, such as knock malfunction lamp lighting etc. & nbsp; [/ QUOTE]
< / DIV>
& nbsp;
exactly agree. I had the same problem in my vehicle, the lpg setting was done, the throat butterfly was cleaned (rubber grease consisted of sediment in the throat butterfly :) shaking when pressing this gas, suddenly collapsing when pulling the foot out of the gas improved ...
08.05.2020 17:00 # 10
eray307
Wow, I was suspecting the undercarriage too, it is interesting.I would be very happy if you could go into more detail about the location and cleaning of this throat butterfly.
08.05.2020 17:00 # 11
rataylan
the same problem exists in my vehicle, I did not go over it, but I was intent on reading what is adaptation and how.
08.05.2020 17:00 # 12
cerci07
[QUOTE = ByHack] [QUOTE = ramtas] hello guys, this is a recommendation related to this topic: adapt your throat butterfly. We repeat the process, the device was already saying the reason of the correction. After 20 seconds after pressing the pedal, turn off completely, that is, turn off the ignition, or it would say that malfunctioning of the knockdown lamp, etc .. faults occur & nbsp; [/ QUOTE]
& nbsp;
I agree exactly. I had the same problem in my vehicle, the lpg setting was done, the throat butterfly was cleaned (rubber grease consisted of sediment in the throat butterfly :) shaking when pressing this gas, suddenly stacked when pulling the foot out of the gas, it improved its shaking ...
good your vehicles are gasoline friend, the vehicle is diesel so there is no throttle.
makes the hitting or shaking event from the flywheel or clutch. There is a volant failure in my vehicle.
08.05.2020 17:00 # 13
mustafah
Have a check on the exhaust system, I think maybe it might be related & nbsp; "Smile"
08.05.2020 17:00 # 14
kuantum
solenoid valves may need to be replaced.
08.05.2020 17:00 # 15
[QUOTE = quantum] solenoid valves may need to be replaced. [/ QUOTE]
Not automatic "Embarrassed" Reviews
08.05.2020 17:00 # 16
metin
[QUOTE = koliva] When I say shrug, I couldn't understand exactly what happened. It would be much more understandable if there was a video.
Find a link to my signature ( for new friends who joined us ) Please.
Brother did I remember that I had such a complaint?. & nbsp;
When going on the cruise, when you released the gas, there was a very slight jolt, and then when you touched the gas, there was a slight jerk. I couldn't solve it either.
08.05.2020 17:00 # 17
[QUOTE = text]
Brother I had such a complaint did you remember?. & Nbsp;
Cruising When you leave the gas when you leave, there was a very slight jolt, then a slight jolt when you touched the gas. I couldn't solve it either.
Yes I remembered the text. Is it the same problem.
08.05.2020 17:00 # 18
inceyasar
are there any friends who can solve this problem?
08.05.2020 17:00 # 19
goktug
today I applied to the master in the gardening industry due to the same problem. Since there are no throat butterflies, he checked other possible parts and found nothing. We had a test drive with the vehicle. he said no problem. I decided not to fall on it when I didn't give any problems on the computer. I think this problem exists in most of our vehicles.
08.05.2020 17:00 # 20
inceyasar
I had the same problem with friends, the master fixed the axle so that he could not move it with a tool and turned the wheel with his hand, and it turned out that there was an axle gap, other masters said that there were all pejoes. I will replace or fill the axle heads, someone you know is doing axle filling work in Ankara
Page : / 2
