please help pejo 206 help
08.05.2020 15:41 # 1
xpejox
hello I have a 2006 model at 206 tiptronic 40955km.I went to ankara big sanaii today and they said that my 4 brakes should be changed also he said that he will replace the steering pump because my steering is extremely hard and he will wear a bounce. Do you have any price suggestions in the price scale? Since it was taken, the gearbox has changed except oil and water (known as pejo tiptronic 33 000). The brake was not touched. . thanks Gülme
08.05.2020 15:41 # 2
If the steering pump is going to fit the boom, the price seems a little salty to me. Replacing the spark plugs also contributes economically to the fuel. If you want to reduce fuel consumption, I recommend LPG.
08.05.2020 15:41 # 3
sercinho
Before the steering pump is replaced, there is a problem in the fine research. I do not realize that the pump is changing. If it is hard, look at the hydraulic oil, it changes according to the brand of the tires.
08.05.2020 15:41 # 4
If you want a reliable pejo master in Ankara, I have been going to the same master for 7 years ...
I bought 2000 model 206 in 2004, I started to go to that master ... and now I have 2006 model 206 feline vehicle, I am still going to the same master, I am very pleased.
08.05.2020 15:41 # 5
xpejox
There are capillary scratches on the belt of the pump and there are screws or nuts under it and 30 TL said.
xpejox 2011-06-23 16:51:12
