Please help me...
08.05.2020 15:08 # 1
ogretmen
Hello friends, I have 307 hdi. Especially on cold days when I turn the ignition in the mornings, the engine is running and the sounds are metallic and the engine stops again. It is as if the engine crashes on something. 7-8 runs after 8 attempts and gives Antipolution error. After working and using it a little bit, the problem disappeared. Then this sound increased a lot more like a tractor. There was no master who did not see, there was no change in the part ... The problem was not solved. If someone who meets the same problem and resolves help, I would be happy.
08.05.2020 15:08 # 2
gokayy
Anyone who knows will definitely answer you shortly, but you should introduce yourself under the heading of our members as follows.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
08.05.2020 15:08 # 3
Unfortunately, we cannot respond to such entries only for information purposes. If you act as required by the forum rules, our friends who have information about your boredom that you have written will be able to respond. Get well soon
08.05.2020 15:08 # 4
ogretmen
Sorry I didn't introduce myself from just novice (not knowing the procedure) since I don't have much internet experience. My name is Mustafa Karakaya, I am 34 years old, I am a mathematics teacher, I hold a bicycle, I stayed in Istanbul for many years, and now I am a trabzon uncle because of my wife. I did not need to write my email because we are already signing up for the forum ( mustafakrky@gmail.com )
08.05.2020 15:08 # 5
Carmania
Welcome, teacher, have a past. If you explain the problem in your vehicle in more detail, I am sure that you will get better results.
08.05.2020 15:08 # 6
ogretmen
One day when I went to the shop, I stopped the car and turned off the ignition, when I realized that I parked it wrong, it didn't work again when I wanted to start it again, tried it by knocking it ... a master said that after seeing the car it was from the battery, the battery and the coals and the dynamo changed ... no problem until 2 weeks ,, After 35 km of road, I parked the car for 5 minutes, then it worked very hard ....... then, as I said above, it started not working in the morning, when I started, it worked like 7-8 times when it insisted that it sounded like rubbing iron and did not work, The engine did not have any problems when it was heated, but the masters said that they did not find the problem in 2 weeks. The car still could not find the problem.
08.05.2020 15:08 # 7
be well soon ... a crazy problem. Did you bring the vehicle to the service?
08.05.2020 15:08 # 8
I think it is necessary to connect the vehicle to the computer and see the error codes.
08.05.2020 15:08 # 9
ogretmen
I did not take it, but although my master asked friends in service and many other masters, nobody could find a cure
08.05.2020 15:08 # 10
ogretmen
I will pray well to those who cure. Gülme
08.05.2020 15:08 # 11
sercinho
hodem, it is a good one, you can not find the solution that you look for in this kind of problems, i think you can go to the authorized service because when you say "change the presentation", the other masters on the left are changing, the parts are not broken in the back, but I am not a competent service, but the problem is not possible, if the problem is not possible, the problem is not possible. they find the price that needs to change the water, and I think they don't have to worry.
08.05.2020 15:08 # 12
ogretmen
You are right, brother, but he also consulted his nephew, who worked in the master service, again, nothing came out.
08.05.2020 15:08 # 13
Carmania
(I sound like it is rubbing iron on iron when I start) My teacher, I see it, I understand from this word, I do not know if it is true or not.
08.05.2020 15:08 # 14
hakan308
Antipolution fault, so there is a problem with your oxygen sensor
08.05.2020 15:08 # 15
[QUOTE = hakan308] Antipolution fault so there is a problem with your oxygen sensor [/ QUOTE]
There might not be. The oxygen sensor is just one. There are dozens like him. It is best to connect to the computer, see the error codes and then discuss it. In the oxygen sensor, the problem will already arise.
08.05.2020 15:08 # 16
ogretmen
Now I called the master, the oxygen sensor is not in my car, he said he has gasoline ..
08.05.2020 15:08 # 17
UGuRs
Firstly, get well soon
[QUOTE = sercinho] hocem, the past has been in the past, you can not find the solution you look for in this kind of problems. they find the problem of giving the problem without giving it, and they say this is the part that needs to change the water price. I think don't worry, bigger troubles can occur [/ QUOTE]
I agree with my friend Sercinho friend, I had a problem with my vehicle not working
industry industry gasoline pump float injector kits could be changed from the brain
I went to the authorized service, I changed the buoy, the problem was solved, the other one was the mirror part, maybe there is something like that, go to the service, I will say that you will have such trouble.
08.05.2020 15:08 # 18
tugrabozan
If it gets harder both in the morning and in the diesel, it seems to me like a glow
08.05.2020 15:08 # 19
[QUOTE = teacher] now I called the master, the oxygen sensor is not in my car, he said he has gasoline .. [/ QUOTE]
I think that phone is a hungry master ... I am not saying anything else ...
08.05.2020 15:08 # 20
boranaydogmus
Sir, does the sound of the vehicle improve when the engine gets hot? If it does not improve, if it continues to work like a tractor, the timing belt may have jumped to the cent when you hit your car to start. If this is the case, the engine will work hard, the sound will become too thick, the performance will decrease gradually, the sibobs will bend gradually and your vehicle will lock the engine somewhere. I do not know why diesel vehicles are said to not be shot and operated especially, but this is how I feel. You think the master looked, he would understand such a situation, but I would say have a check.
Page : / 2
