Please help lice
19.11.2020 19:30 # 1
hknhrrli
Good luck to everybody, I am with you with berlingo as you know there is no form for berlingo I wanted to ask you because it is almost identical with the partner I have 2013 berlingom. When I start the tool in 96 thousand, it works without any problem. It happens when the engine is fully warmed up, there is no problem in the check-in, why does anyone have the information? It happened the same when the weather got cold last year. They said diesel filter. I changed it. I could not find a solution. Injector cleaner.
19.11.2020 19:49 # 2
ismailkaya
Shall you share a video?
19.11.2020 19:55 # 3
hknhrrli
I did not have the opportunity to take the video, but how can I say, there is no problem in the vehicle while working in the vehicle. When the rev counter reaches 70, there is a noticeable shaking in idle.
20.11.2020 09:11 # 4
clean the airdebimeter, sir. And from which station do you get the fuel?
20.11.2020 09:22 # 5
hknhrrli
I usually buy opet or shell euro
20.11.2020 10:24 # 6
Well, teacher, did they check the injector values?
20.11.2020 10:41 # 7
hknhrrli
[QUOTE = sonerkyl] Well, my teacher checked the injector values [/ QUOTE] No injectors were not checked last year, the same happened.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
