Please help for god's sake
08.05.2020 18:25 # 1
suleymangulgun003
First of all, good night to everyone, let me sleep new from opium 1 year ago, I bought a 307 hdi 1.4, 2005 model vehicle did not make black smoke because of water extraction, we made a complete engine before the engine was engine, the engine was not blown black engine, the original turbo was taken, the injectors were maintained but after the engine was engine the black smoke did not cut the injector, I got the zero turbo em oil from the turbocharger, they said they looked at the turbo.
08.05.2020 18:25 # 2
barishrocker
Last time it was as if I had read that the egr valve could also cause this.
08.05.2020 18:25 # 3
saruhan
Dude have the flow meter checked.
08.05.2020 18:25 # 4
alpercakan
Shell v-power gtl + buy fuel If carbonclean is not interrupted, check the flow meter Egr there is nothing else to do because there is no problem in traction, I think you do not need to obsess diesel car after all.
08.05.2020 18:25 # 5
ahmet_bjk
It is caused by either the turbo or the engine since it starts to smoke black after the engine is made and the turbo is replaced. Since you have the turbo checked, there must be a problem with the engine.
Which company fuel do you use? Does it smoke black smoke even at idle?
08.05.2020 18:25 # 6
suleymangulgun003
No black smoke in the role, it only makes black smoke on departures
I am using bp diesel, before that I used the oil office
08.05.2020 18:25 # 7
cavit cevo
brother, it's okay in the vehicle, I think try the fuel as a shell
08.05.2020 18:25 # 8
Alicilik
What color will the burning gas come out, Hojam? 206 of the Arkadş chip was making a black cloud like a municipal truck. If you don't have a performance loss in a diesel vehicle, it is not a long time to be stuck.
08.05.2020 18:25 # 9
suleymangulgun003
There is no performance loss, but after the engine is built from scratch, it will bogle if the black smoke comes out.
08.05.2020 18:25 # 10
oguzhan29
Take a look at it
08.05.2020 18:25 # 11
suleymangulgun003
injectors were maintained, the tires were changed
turbo original 0 received stuck
oil office 10 * 40
yes it has a tightening sound coming from the injectors.
does not give error
the vehicle was built 12000 km, the engine was built 1450 km
egr chewed
no lubrication in the car's engine coolant
The engine of the vehicle + knife was not modified. 0 engine was completed in the same way as the original values.
08.05.2020 18:25 # 12
suleymangulgun003
There is no one to help the subject, galıbaaaa ....
08.05.2020 18:25 # 13
kivanc
[QUOTE = suleymangulgun003] injectors serviced tires changed
oil office 10 * 40
does not give error
egr chewed
Then I think there is no need to worry. Diesel vehicle throws smoke.
08.05.2020 18:25 # 14
suleymangulgun003
yes tool 2005 1.4
