Please help for gas problem at 206
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:48 # 1
gngburak
Hi everyone,
I'm running the vehicle (there is a sequential weapon)
is running Stop after 3-4 seconds when the gas passes .
so there is no gas. what do you think could be the problem ...
08.05.2020 16:48 # 2
zaxx54
Sa sister same & nbsp; problem we had in our car trunk lock changed oxygen sensor check & nbsp; fix ..
08.05.2020 16:48 # 3
falan
[QUOTE = gngburak] hello to everyone
I'm running the tool (there is a sequential wizard)
is running 3-4 seconds later, the gas stops when it passes.
so there is no gas. what do you think could be the problem ... Normally it is necessary to switch to gas after 1-2 km ... you will have a gas adjustment ..
08.05.2020 16:48 # 4
monur
[QUOTE = gngburak] friends greet everyone
is running 3-4 seconds later, the gas stops as it passes.
so there is no gas. What do you think the problem might be ...
There is a silicon diaphragm inside the regulator of LPG and your problem is strongly caused by this possible diaphragm.
08.05.2020 16:48 # 5
Sedat Yildirim
I had my 206 automatic vehicle fitted with an Atiker inline system lpg system.
My vehicle was passing on the gas after 1.5-2 Km. Every day 7.5 km in the evening, 7.5 km. I travel to work. 15 km of the road was doing 3-4 km with gasoline.
I took the gas to the master I was admitting, I wanted the gas to be activated earlier, because I was buying 15-20 TL gasoline in each cylinder filling, supposedly my car was gassed. , the master told me this is normal, if we take it earlier, he said, your vehicle will stop, you said when the weather is warmer.
I did so, I went when the weather was warming. Now the engine changes to gas when it reaches 40 degrees, it changes between 50 meters and 600 meters according to the temperature
state of the boiler. He said.
He said the ignition is related to your system. up,
the vehicle does not start without taking the gear to the park position.
It can be operated by knocking again in manual gears, but,
automatic gears, this problem is needed ...
I don't know this either ...
Sedat Yıldırım 2012-05-28 12:47:31
