Please Help For "Anti Pollution Fault". |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 19:19 | # 1 |
onuralyaz |
My vehicle is 2006 model 207 1.4 Trendy 16v (90hp) Gasoline model and it is 65.000 km. I just bought the vehicle. The next maintenance is written on the service paper, which has been given to me periodically, such as oil, water, air filter, including the Triger at 63200 km. I put the car in expertise, when it was connected to the computer, it only gave error in the ignition system. Now I deleted it, I don't think it will cause problems until the next maintenance, they said from the service. But it has been 3 days since I bought the vehicle and there was no problem in 3 days performance. Yesterday, the windows made mist, I gave the air conditioner to the windows, opened it to the end, the car started to work with an incredible sound and shaking, I turned it off after 2 minutes, I set off, the service light came on and the Anti Pollution Fault error gave the vehicle. After this error, when it came to 3000 cycles, it started not to eat gas, fainting on the slope and shaking at idle. I came home and left, and I was able to let me down again after 1 hour, I ran down again, this time it did not burn, the car continued to help with its old performance. After 15 minutes, the light came on again and the car became cumbersome again. The car is airplane when the light is off, the light is on the wheelbarrow. A lot of things are said when I search for what could be the reason for this. The service said the ignition system error could be the reason for this? I know that spark plugs can. Can the air filter do it because the car cannot provide the air flow from the pollen filter pollution? I bought gasoline from Shell, there is a half tank of gasoline, but it happened in the evening of the day I bought gasoline, which makes me think. I'm waiting for your help.
| 08.05.2020 19:19 | # 2 |
sonerkyl |
Welcome. If you examine the link I provided, you can find solutions. wish you use it without any trouble http://forum.peugeotturkey.com/forum_posts.asp?tıd=20997
| 08.05.2020 19:19 | # 3 |
Have the oxygen sensor at the entrance of the vehicle checked and the lambda sensor connected to the exhaust at the exit.
| 08.05.2020 19:19 | # 4 |
Well, I don't know if the brothers have any solution, but if the rearview mirror inside the car is shaking enough to shake, I changed the coil since my car was so old that the coil became old. The price is 200 TL original. 140 TL supplier industry. My advice to you is original regardless of which piece. In addition, all of the filters accumulate 100 TL and they are also overhauled. Mine is recommended. Maybe this may be the problem. But I also listen to what other friends write. Because not adept at finding fault anyone turkiyenin hocb in place. But if you research it, you find it. Get well soon
| 08.05.2020 19:19 | # 5 |
Efe-Pojo |
the problem is most likely caused by firing, already on the computer. If it was caused by sensors, the antipollution would always write, if it was written and destroyed, firing is very likely. the coil seems to be welded.
| 08.05.2020 19:19 | # 6 |
onuralyaz |
Hello, we solved the problem, one of the spark plugs took water, it was not working rusty, so the coil also failed, and 4 spark plugs changed 300 TL including labor. Get well soon.
