Please help about the oil mixed with the water.
08.05.2020 19:59 # 1
alierdal0335
My vehicle was heated 2 times due to not turning on the fan. Oil was mixed with water. My master said it was from the oil cooler, we replaced the metal part of the oil cooler. Then I started to use antifreeze, I feel like I am seeing oil again slightly. In the heat, it should be up to 100.
08.05.2020 19:59 # 2
I think that before replacing, I say change an antifreeze again, and with this observation, radiator cleaner was used while changing the antirust. If not used, oil and rust institutions remaining in the system can cause this. According to him, we have to observe again.
08.05.2020 19:59 # 3
alierdal0335
Brother I did not use the master did not say anything, I am in Cyprus, do not understand properly, do you suggest that I apply radiator cleaner and try again?
08.05.2020 19:59 # 4
Exactly, but let me point out, as far as I understood, the radiator cleaner used with water will remove the oil and rust in the system. As a result, the ratio of oil to water increases, because the places where the rust and deposits in the system will be cleaned, water leaks will occur. extra charges can be drilled, the radiator can be drilled, rusty places will be cleaned.
08.05.2020 19:59 # 5
alierdal0335
Okay brother, let me try it today and where do I drain the water from the radiator exactly?
08.05.2020 19:59 # 6
At the bottom there is a big hose, take out the clamp with the help of pliers, it is a little hard Open the cover of the reserve water tank and let the open well empty. only some water will remain in the engine. There was even a subject.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=23736&title=sogutma-suyumotor-blogu-dahil-nasil-degistiril is
08.05.2020 19:59 # 7
alierdal0335
Thank you bro I will clean up and write the developments
08.05.2020 19:59 # 8
canbicerr
Hello hello, I have 206 in me, when I got the car, oil was mixed in the water tank, the inside of the water looked obvious. About 1 or 1.5 months ago, I changed the water tank, cleaned it and put antifreeze right now, the temperature indicator does not exceed 90. In the past, 90 were more than one or two stages (depending on forcing the vehicle)
I wrote for informative purposes. Good luck with.
08.05.2020 19:59 # 9
alierdal0335
Thank you my dear brother, I will do it tomorrow morning. Let's see what will happen to me.
