please help |
| 08.05.2020 16:48 | # 1 |
intermittent malfunction bridging the converter solenoid valve plus short circuit at the end I took my car to the master who understood the automatic transmission repair in samsun and said that the solenoids are defective, I left it to the master, I came to the master, because of my work, he changed the master and knock is gone and said i'm gonna get my car on monday but i got a problem in my head & nbsp; I wonder if the malfunctions that I mentioned above are just a solenoid or if there is a problem with the vehicle's electrical installation, but there is a situation. |
| 08.05.2020 16:48 | # 2 |
metin |
I wish you would take your vehicle to an authorized service. As far as I understand, he could not do the human job you call a master like a man. It has most likely operated without introducing new solenoids. Old solenoids and new solenoids work with different frequencies. Therefore, when a new type of solenoid is installed, it is necessary to connect the vehicle to the computer and introduce new ones. Otherwise, they work halfway as you mentioned. & Nbsp; This is my opinion.
| 08.05.2020 16:48 | # 3 |
Well, I said it to my teacher, but he said that there is no introduction, he just said that I deleted the adaptation and the failure. let's do it
| 08.05.2020 16:48 | # 4 |
[QUOTE = famekontor] Well, my teacher said it too, but it said no introduction, I just deleted the adaptation and the fault. let's do it [/ QUOTE] ECU software needs to be updated, which you can't do with clone PP2000s. Authorized service registration is required. Reviews |
| 08.05.2020 16:48 | # 5 |
there is no service in our country :) I bought the vehicle today, the failure was lost, the anarmality in the gear changes has improved. Normally, 3 shifts in the morning, the snow and sports mode lights should have turned on. I will try again and share the information here today.
| 08.05.2020 16:48 | # 6 |
[QUOTE = famekontor] if there was no service in our country :) I bought the vehicle today, the malfunction in the lost gear shifts disappeared. I will try again and share the information here today. [/ QUOTE] Where is your hometown? If you can write your profile, the next comments will be made accordingly. Insallah does not repeat again. |
| 08.05.2020 16:48 | # 7 |
metin |
[QUOTE = famekontor] if there was no service in our country :) I bought the vehicle today, the malfunction in the lost gear shifts disappeared. I will try again and share the information here today. [/ QUOTE] Get past it. I am glad that the malfunction has improved, I hope it will not recur. What did your master do and do?
| 08.05.2020 16:48 | # 8 |
homeland amasya only electro valves have changed before, but the first valves I bought turned out to be defective with new ones workmanship + oil + 2 electro valves I paid 450 TL in total.
| 08.05.2020 16:48 | # 9 |
metin |
[QUOTE = famekontor] hometown amasya only electro valves have changed before, but the first valves I bought have changed with new ones. What is your km?
| 08.05.2020 16:48 | # 10 |
The snow sports mod was burned at 117,000 today, but the gear shifts are very smooth & nbsp;
| 08.05.2020 16:48 | # 11 |
Firstly, get well soon. Automatic transmission is not the fee of every master, but unfortunately we have to rely on helplessly. I will leave tomorrow vehicle gears will be checked, I hope there will be no problem
