PLEASE HELP 206 FAULT LAMPS
08.05.2020 21:18 # 1
okah
Hello, in the rain
ABS AND HAND FIRE FIRST
AFTER THE AIRBAG AND ENGINE LIGHT LIGHTS ARE NOT RUNNING AT THE SPEED INDICATOR
4-5 DAYS AFTER AIR IS HOT, AIRBAG MOTOR IS TURNING OUT THE SPEED INDICATOR IS OPERATING
ABS AND HAND BRAKE IS STILL ON
I CAN'T FIND A SOLUTION
08.05.2020 21:18 # 2
Orcun.Dmr
Is there a sound system in the vehicle?
08.05.2020 21:18 # 3
tungajo
I say look at the sockets. Rainy weather dio hot weather dio.
It came in the rain that happened to me. Oil lamp and mosaic filter burned out.
I took it to the master. He took the sockets and went away.
08.05.2020 21:18 # 4
okah
There is no sound system in the vehicle, there is nothing on behalf of the modified only the tape is different from the original
XT rain and headlight sensor model
08.05.2020 21:18 # 5
okah
for example my brain sockets
08.05.2020 21:18 # 6
tungajo
First of all, you need to look at the sensors, and you better connect the vehicle to the computer
08.05.2020 21:18 # 7
littlenikksay
I had a similar problem, first the battery lamp was on, then the abs airbag all were on, then the brightness of the indicator lights fell.
I suggest you have a check that the car charger and battery have all changed.
