playstation connected to vehicle illustrated
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 15:59 # 1
34sea45
. 34sea45 2011-11-12 03:04:46
08.05.2020 15:59 # 2
forewer_fb
Let me now say that, after deciding which devices to connect to the vehicle in total, there are 12 v - 220 v inverters according to the total power of the devices and they will do the job when you buy them. because inverters are sold in different powers and their prices are changing accordingly. The important thing is the current that the devices you connect will draw. Other than that, you don't need to buy a spare battery. It is beneficial for the inverter to receive a solid and direct battery supply.
08.05.2020 15:59 # 3
How did I drop the PS2's voltage input? Was a cable coming out of it, was it directly plugged in, or was there an adapter out there ??? Is it coming to the device with a 220V mast?
If it comes to the device, it is necessary to connect the appropriate power 12-220 converter by calculating how many watts of power the device consumes and how many watts will be needed in the other parts to be connected.
Also, the cable that feeds the amp will feed the system there, no more ...
08.05.2020 15:59 # 4
34sea45
There was a little change in the project. For the 17 inch vehicles, there is a ceiling type monitor, the electricity will be drawn for the playstation, but the ps I heard have been 12v with a small adjustment. Do you have any information?
08.05.2020 15:59 # 5
forewer_fb
[QUOTE = 34sea45] there has been a bit of change in the project Let's get the ceiling type monitor for 17 inch vehicles, electricity will be drawn for playstation only but the ps I heard have been 12v with a small adjustment Do you have any information?
The most robust will be taken directly from the inverter, because the inverters have regulator circuits that adjust the voltage and current, which prevents the device's adapter or power unit from seeing.
08.05.2020 15:59 # 6
Then the monitor will work with direct 12v. It may already be working with 12v in monitors that we use at home. I had a monitor, the adapter was outside, for example, it is a different matter.
If the PS2's adapter is outside, you do not connect the adapter and give it a direct 12v.
08.05.2020 15:59 # 7
[QUOTE = forewer_fb] [QUOTE = 34sea45] there has been some change in the project. For the ceiling type monitor for 17 inc vehicles, electricity will be drawn for playstation only but the ps I heard have been 12v with a small adjustment Do you have any information?
The most robust will be taken directly from the inverter, because the inverters have regulator circuits that adjust the voltage and current, which prevents the device's adapter or power unit from seeing. [/ QUOTE]
If there is a regulator inside the inverter, this is very good ...
08.05.2020 15:59 # 8
34sea45
yes monitor 12v no problem with it ps in my plumber said they open 12 said we will open it but I do not want to disable the angle of work :)
08.05.2020 15:59 # 9
burakdmr
what are you doing, man, you will live in a car :)) play ps ni splay in your home seat, led tv what you enjoy :)) ..
still be easy :)
08.05.2020 15:59 # 10
forewer_fb
[QUOTE = 34sea45] yes monitor 12v no problem with it ps in plumber said they have 12 said we will turn it on, but I do not want to disable the angle of work :)
my brother, you have a project like this, do not mind. there is a proverb very nice "I am not rich enough to pay for cheap goods" I want you to know that if the power board lights up tomorrow the next day, it will be much more expensive than the inverter. You will have done twice the busefer, beautifully connect the puller system oohhh look at your pleasure. this is my personal opinion Göz Kırpma
08.05.2020 15:59 # 11
A friend wants to make a different practice. I appreciate such extraordinary practices Göz Kırpma
08.05.2020 15:59 # 12
34sea45
[QUOTE = burakdmr] what are you doing, man will you live in the car :)) play ps ni in the seat of your seat, plug in led tv what you enjoy :)) ..
still be easy :)
I only use the car on the weekends. Naturally, I also have fun. I am not able to use the baggage because of the bass.
08.05.2020 15:59 # 13
forewer_fb
[QUOTE = 34sea45] [QUOTE = burakdmr] what are you doing, man will you live in the car :)
still be easy :)
As cecoli says, I fully support such applications, after all, unusual applications. by the way, nice idea in ps tournament Göz Kırpma
08.05.2020 15:59 # 14
34sea45
If there is nothing wrong, we will do it tonight, if it grows, we will try to meet tomorrow :)
08.05.2020 15:59 # 15
[QUOTE = forewer_fb] [QUOTE = 34sea45] yes monitor 12v no problem with it ps in it my plumber said 12 they open it up, he said we will bind it but :)
my brother, you have a project like this, do not mind. there is a proverb very nice "I am not rich enough to pay for cheap goods" I want you to know that if the power board lights up tomorrow the next day, it will be much more expensive than the inverter. You will have done twice the busefer, beautifully connect the puller system oohhh look at your pleasure. this is my personal opinion Göz Kırpma [/ QUOTE]
Here, our ancestor remembers the deceased Mr. Sakıp Sabancı with respect. I agree with my Forever_fb brother :)
08.05.2020 15:59 # 16
34sea45
I have 1 electronics shop next to me, I asked him to convert ps to 12v, you say nothing, you say you use it, but I don't know.
08.05.2020 15:59 # 17
Maybe you can give an idea in this video. For you to apply after 2:13. The man put connectors for Xbox in the trunk and placed the screen on the trunk lid.
[TUBE] 9jpnbnhepmw [/ TUBE]
Koliva 2011-08-12 11:18:53
08.05.2020 15:59 # 18
34sea45
unfortunately, my trunk lid is not opening so :) I will put it up and down. I will set it up to the right. I will put an extra column on the left.
08.05.2020 15:59 # 19
[QUOTE = 34sea45] my tailgate doesn't open so much, unfortunately :) I will put it up and down, I will put the extra column to the right and I will connect it to the system for the system.
Let me share what I know. Even if Playstation does not work with a 12 volt supply (i.e. external adapter), there is a transformer inside the box of the device and it converts 220 to 12 or less voltages. All you have to do is turn on the device and measure the outputs with the voltmeter. I think it's probably 12 volts, but it still doesn't hurt to be sure.
Another point is that the main problem is not PS2. This tool normally takes 72 Watts. No problem here. The main problem is that when this 72 Watt is combined with the screen you will put, it will reveal a power requirement of approximately 300-400 Watt. Generally, inverters are 100W-150W. I don't know how much it costs.
08.05.2020 15:59 # 20
34sea45
Thanks for the information, I changed the monitor with the monitor for the vehicles. I am already looking for a solution for 12 V ps. I intend to open and connect it again.
Page : / 3
