plates of
08.05.2020 15:10 # 1
oguzhan29
First of all, I wish you a good evening, I would have a question.
08.05.2020 15:10 # 2
If you apply too much silicone, you will get a little bit of sting. A little silicone would have been enough.
08.05.2020 15:10 # 3
oguzhan29
the back normally took a little too long to hold the front so how should I do the scaling
08.05.2020 15:10 # 4
only_younus
Well, I had a hard time removing it. I started with a big bread knife
08.05.2020 15:10 # 5
ErcaNKarsI
the line will do the job of removing the rope;)
08.05.2020 15:10 # 6
Muhammet CAKIR
I wish it would be easier to disassemble if you used double-sided tape. Also, if black areas are to be painted, they are easy but if you say white, you should use phosphorous paint.
08.05.2020 15:10 # 7
3rkans
It has a very simple disassembly, there are thin elastic wires, usually motorcycles will tighten the brake wire or line between the top and downwards, you will pull it slowly and cut the silicone.
08.05.2020 15:10 # 8
Mesut
Oh, do not cut your hands when you say sikonu shoot it.
08.05.2020 15:10 # 9
oguzhan29
Thank you all, my back plate is very nice, it's okay. I just did my front plate to paint with a pencil.
08.05.2020 15:10 # 10
m.peker
you can disassemble very easily with thin wire
08.05.2020 15:10 # 11
oguzhan29
ok guys thanks i will cut it out with a knife or something like that
