Plate Restoration
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 14:13 # 1
IsmailAtes
While I wanted to clean the paint with thinner as a result of paint dripping on the plate, it was slightly deleted in the articles. This plate got worse with the effect of time and I applied to such an application.
Materials:
-Permanent pencil (I can recommend it in stationery, I recommend M series; it has a thick tip.)
-Maket knife
-Paper or Duct Tape (Preferably paper tape)
Since we cannot find paper tape, we first tape all the numbers and letters on the duct tape.
Then, with the help of a utility knife, we mask the external places of the place where we want to cut and paint the edges of each character and start painting with a Permanent pencil.
Finally, we remove the masks we made with the tape and clean some leaked paints with the tip of the utility knife.
The important issue here is that we paint the pencil with the same parallelism because we paint it with a pencil so that it doesn't get wavy and we paint and finish each character at once, because the ink of the pencil has a quick-drying structure.
Good luck with..
08.05.2020 14:13 # 2
cerci07
Tskler for sharing this beautiful plate I have a project in mind about painting this plate.
If we paint the numerical part of the project with a phosphor paint, I would appreciate if there is a possibility that the plate will shine in the photographs taken by radars and the possibility that the entire plate will shine and the numbers will not be read. Sırıtma
08.05.2020 14:13 # 3
eliminating my health sister beautiful work
08.05.2020 14:13 # 4
mabolla
I did the same method about 5 months ago. only the paint of the characters had been deleted.
pressure water and sticking flies are the ones that damage the plates the most
08.05.2020 14:13 # 5
IsmailAtes
Yes, Mustafa Bey, there is a way like you said, but you can save your plate in the cameras by spraying only a transparent spray, not by painting. Gülme
You are right, they are the most important factors that damage the plate, but with such a simple method they can have a better appearance than before. Gülme
