Plastic brain cap
08.05.2020 21:24 # 1
kaan206
Hi guys, I bought a plastic brain cap on my vehicle.
But I couldn't. & Nbsp;
I think it's necessary to fix the plastic cap by unscrewing the nuts on both sides of the brain and tightening the nuts. < / div>
However, in order to remove the nut on the back, it is necessary to remove the brain. 😱
Apart from these two screws that hold the brain steady, there is a separate screw.
Since I did not have the necessary key in my hand, I decided to handle this work in my master. .
There is a pressure sensor in the plastic plug in the middle of the brain, they can not detect the pressure.
& nbsp; But many 206 also have this plastic cover. & nbsp;
Their brain is not warming pressure. sensors are not closing?
The worst plastic cover is that the pressure sensor h I'm going to make a hole in the scissors. 19:23:46
08.05.2020 21:24 # 2
omerb
I think it can't trap that much heat in.
The heat will of course come out of an empty space. Ecu stands in an aluminum chamber. It is attached to the bonnet and removes most of the heat from here. Make sure it is in full contact with the bodywork again. When it comes to the issue of holes, I think it will eat open anywhere. Even if it is pinhole, I think it feels atmospheric pressure
08.05.2020 21:24 # 3
kaan206
actual
08.05.2020 21:24 # 4
kaan206
the cover is applied with a hole
H
Comments ???
kaan206 2019-12-24 22:32:45
08.05.2020 21:24 # 5
omerb
I think it's nice. Thanks for your effort.
08.05.2020 21:24 # 6
kaan206
[QUOTE = omerb] I think it's nice. Thanks for your effort. [/ QUOTE]
Thank you bro
09.01.2021 15:22 # 7
Bayrambugra
Where did you get the master cap? Also, isn't the purpose of the cover to prevent water from escaping to the ecu? You drilled a hole, water can enter from there?
