Plain Sound System
08.05.2020 19:07 # 1
ysf_syfttn
Friends I do not think of installing a simple car amplifier-bass in my vehicle. I have thrown down the link of tape and ovals. Are these enough or would you suggest that I wear 4 if this tape lifts 4 ovals ? Thank you in advance for your recommendations . Smile
08.05.2020 19:07 # 2
ysf_syfttn
Does anyone have knowledge?
08.05.2020 19:07 # 3
GokhaN
Get the original 2 sets mid door to your doors 4 channel amp is the best simple system
08.05.2020 19:07 # 4
oguzhan29
If you want clean and clear sound in my opinion, 4 channel amps and 4 doors front 16cm back 13 cm component buy music to taste
08.05.2020 19:07 # 5
ysf_syfttn
Doesn't the amplifier remove the 4 ovals?
08.05.2020 19:07 # 6
GokhaN
Put it here, why do you pierce it and turn it into a falcon?
08.05.2020 19:07 # 7
ysf_syfttn
Then I take 4 pioneer mid, plug it into the doors and complete the system with a bidet amplifier, thank you :)
08.05.2020 19:07 # 8
KuzuX
Dude don't mess with the oval moval. I don't use it at home. You are going to buy 2 sets of 4 door columns, pioneer is good and cheap. You get 1 2400W roadstar sterio amp and you get the pioneer tape. If you want, you can buy 1000w champion series bass in a suitable buffet . Tape the stomachs and tie them to the amphitheater. Do not let me put an oval in my panzot, you will get an awful sound in the panzot, and your trunk will squeal from those ovals. Well, if I say that I can cast a solid fiber cabin, it is separate :)
08.05.2020 19:07 # 9
ardem
[QUOTE = oguzhan29] if you want clean and clear sound in myself 4 channel amps and 4 doors prevent 16cm rear 13 cm component get the taste of music [/ QUOTE]
It would be appropriate to do this with the original tape of my 2012 model 206 plus.
I ardee 2015-02-28 19:22:49
08.05.2020 19:07 # 10
samet206
I think the md team is good. In my place, my advice will be as the friends say, if there is no amphitheater, you can take the speaker that is suitable for the door dimensions or feed it with low power and feed it with the tape.
08.05.2020 19:07 # 11
Alicilik
There is a ready package system. I will give 206 + installed and even + 90tl control apparatus. Plug night.
in http://forum.peugeotturkey.com/forum_posts.asp?tıd=38629&title=alicilik-ses-sistemi-satis
