piranha encore joystick connection
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:48 # 1
alp2525
I can help those who cannot use the piranha encore 7 device and activate the steering control.
08.05.2020 16:48 # 2
Alicilik
Hello dear,
Can you open up a little bit of health and how did you do it?
08.05.2020 16:48 # 3
alp2525
when we disassemble the arm, we see a socket on the arm, and if I do not remember correctly on this socket, 3 parts on the right are negative for all, so when we try to push one end of the avometer to the other end to the other inputs one by one, we can see that it already completes the circuit when we press the buttons in sequence and if there is any electronic information, it is easy to use again. We are soldering 60 cm long wires to the socket ends, respectively.
then there are copper plates with perforated holes on it. I used 6 resistors to activate all of them) we solder the cable ends to one cable for each of these resistors. The other ends of the resistors are all connected to each other. We connect this cable on the device that writes the management cable at the other end of the resistors to the chassis cable where it is connected. If you are using this device and also have a frame problem, I think there is an alternative.
08.05.2020 16:48 # 4
Alicilik
Well, good health. I just wanted to learn the system. Did you use resistor cam ohms?
As I do not know, I ask, how is the remote input of the device you specified?
08.05.2020 16:48 # 5
alp2525
actual
08.05.2020 16:48 # 6
Hodja, can you take a picture of the vehicle and put it on the tape.
08.05.2020 16:48 # 7
alp2525
slm modified and tuning part COMPLETELY 307 ME & nbsp; ITS OWN APPLICATIONS TITLE IN THE TITLE & nbsp; I made the frame of the pictures myself with lath and covered with carbon.
08.05.2020 16:48 # 8
alp2525
You can review it from the link here http://forum.peugeotturkey.com/forum_posts.asp?tıd=23216&title=tamamen-kendi-yaptiim-307me-uygulamalar-incele & nbsp;
08.05.2020 16:48 # 9
alp2525
frankly gives the right to money equipped according to the device price
08.05.2020 16:48 # 10
nebituran
I guess you are at the entrance of the master. I'm in the army unit. Can I activate this arm event. Can you help me? Thank you from now. nebituran 2012-09-29 16:03:50
08.05.2020 16:48 # 11
alp2525
SLM SISTER MSJ I HAVE RECEIVED FROM ITS NEW VEHICLE GIRED, I WAS NOT GIRESUNLU, I DON'T DUTY IN ERZURUM I SOLD MY VEHICLE IN THE LAST WEEK :) I HAVE EXPLAINED HOW I HAVE EXPLAINED MSJ AT THE TOP, WHEN I HAVE EXPLAINED MSJ AT ITS SAME, I HAVE EXTENDED WHAT IS MSI AT THE SAME TIME.
08.05.2020 16:48 # 12
byforget
I HAVE RECEIVED THE SAME TAPE PICTURE OR MORE DETAILED CAN YOU TELL THANKS
08.05.2020 16:48 # 13
insufferable
friends will be my request from here encore user friends can send me the device navigation map when i say update i did not have a backup deleted deleted i get error i can't open navigation anymore. Can you help me: /
