pionerr 9650 animated
08.05.2020 15:09 # 1
Mesut
SA friends ... Canlar ... this day my friend decided to sell the backup tape in his hand and I wanted to share it .. he said 250 with the price of the device and will make me easy to hand the price is the only problem I will be giving me 2 3 pieces. I hope to take your opinions in the absence of it .... Thank you to all the friends who have contributed to my work .....
* The device has a built-in Digital Signal Processor and THREE amplifier outputs and is one of the most professional devices of music systems.
Click Here To Open In Its Original Size (800x600 And 92KB)
Key features DEH-P9600MP
MP3 / WMA / WAV CD playback
Dual faceplate design
Color Organic EL
New DSP with Auto Time Alignment, Auto EQ, and Burr Brown 1-bit DAC with 24-bit resolution
Standard / 3-Way Network mode
Pioneer`s OEL Screensaver Studio ready
MOSFET 50 W x 4 amplifier
IP-Bus (MCD, DAB, TV, 2 EXT)
Main features DEH-P9600MP
Display illumination COLOR ORGANIC EL
Cellular telephone auto muting Yes
iPod® adapter ready Yes
No. of Radio Presets 24
Max. output power (watts) MOSFET 4 x 50 W
RCA Preout 3 (F + R + S / W)
High Voltage Output Yes
Features - General DEH-P9600MP
Multi-CD Control Yes
CD Text Yes
Source TV Control Yes
DAB Tuner Control Yes
Source DVD Control Yes
List Search Function Yes
External unit control via IP-Bus 2
AUX-In (with optional CD-RB20) Yes
Remote control Included
Hard-wired remote input Yes
ISO Connector ready Yes
Rotary volume Yes
Front Panel Auto-flap mechanism (motorized)
Removable Front Panel Yes
Speaker input for hands-free Yes
Flexible angle installation 0-60 °
Features - Tuner DEH-P9600MP
Adaptive RDS (PI, PS, AF, TP / TA) Yes
PTY (Search and Alarm) Yes
News interrupt feature Yes
Radio Text Yes
ARC FM D4Q
PNS (Pulse Noise Suppressor) Yes
BSM (Best Stations Memory) Yes
Features - CD player DEH-P9600MP
Oversampling digital filter 8x
D / A Converter (Burr Brown) 1- Bit
Fast forward / reverse Yes / Yes
Track Search / Scan / Repeat Yes / Yes / Yes
Track / Manual search Yes / Yes
Random Play Yes
Last position memory Yes
Disc Title Memory Yes
CD Text Yes
CD-R Playback Yes
MP3 Yes
Windows Media ™ Audio Yes
CD-RW Playback Yes
WAV Yes
Features - Audio / Amplifier DEH-P9600MP
Continuous output power (DIN45324, + B = 14.4 V) 4 x 27 W
Max. preout voltage (V / Ohms) 6.5
Built in DSP Yes
Graphic equaliser 13-band
Listening Position Selector Yes
Preset equaliser 5-mode
Auto Time Alignment Yes
Auto EQ Yes
BBE Yes
HPF Yes
LPF Yes
3 way network Yes
Digital ASL (Automatic Sound Leveliser) Yes
Spectrum analyzer Yes
L / R level meter Yes
Level Indicator Yes
Loudness Yes
Source Level Adjuster Yes
Fader Yes
Specifications - FM DEH-P9600MP
Frequency range 87.5 - 108 MHz
Usable sensitivity (75 ohms) 8 (0.7) dBf / µV
S / N ratio 75 dB
Frequency response 30 - 15,000 Hz
Stereo separation 45 dB
Specifications - MW DEH-P9600MP
Frequency range 531 - 1,602 kHz
Usable sensitivity 18 µV
Specifications - LW DEH-P9600MP
Frequency range 153 - 281 kHz
Usable sensitivity 30 µV
Specifications - CD DEH-P9600MP
Frequency Characteristics 5 - 20,000 Hz
S / N ratio 99 dB / 1 kHz
Dynamic range 95 dB / 1 kHz
Specifications - General DEH-P9600MP
Chassis size (W x H x D) 178 x 50 x 157 mm
__________________
08.05.2020 15:09 # 2
dukenukem82
the control is not used much, don't bother him, if you need such a device, don't miss it Thumbs Up No USB and SD inputs.
08.05.2020 15:09 # 3
Mesut
he does not have the correct usb fln, but he already has an iphone entry, did I throw an mp3? :D
08.05.2020 15:09 # 4
or this tape. If you are good enough, do not miss. if it is ok :))
but this engine has a little risk of failure. I'll remind him too. Because it is the fate of such motorized moving parts. but another one in use with pleasure :)))))))
this is already a top serial tape ..
the cecol 2011-03-08 12:51:37
08.05.2020 15:09 # 5
dukenukem82
yes i saw the entry then buy it directly from the owner 450-650 TL or something
08.05.2020 15:09 # 6
Mesut
All right, I was gone.)))) Good luck, friends.
08.05.2020 15:09 # 7
After installing L7, you will give 2 turns :))
08.05.2020 15:09 # 8
Mesut
ABI Taz` n get yaaa :)))))))))
08.05.2020 15:09 # 9
Muhammet CAKIR
Sırıtma good luck my brother I think you bought it :)
08.05.2020 15:09 # 10
Mesut
I bought it, we have a meeting with the friends of the c.
08.05.2020 15:09 # 11
No USB Disadvantage brother according to him
08.05.2020 15:09 # 12
Fills the CD inside, so it handles the mp3. its okay for you it's okay :))
08.05.2020 15:09 # 13
Mesut
aynn teyıb very nice :)) I write a cd is not a problem anyway, all I do with pleasure is to listen to music :)))
