Pioneer Tape Models
08.05.2020 17:19 # 1
Alicilik
Hello friends,
Pioneer, which is the oldest and number one brand in the field of everyone, never fails to compromise on its quality even though it turns into china over time. It is equalizing many brands that entered the market later. It was a bit like advertising, but in order to raise the awareness of the user, I will share the subject published on another site here.
Introducing the 2013-1012-2011 models of Pioneer's most used models (one eye mid-range).
The few products in general & nbsp; If there is a desired model introduced, I try to explain it in more detail.
Alicilik 2013-01-24 09:32:56
08.05.2020 17:19 # 2
Alicilik
2013- Multi-colored panels and mixtrax features are available. It doesn't break the spirit of the front panel, it is an old tradition, USB inputs (those who use USB memory will not like it very much), 4v 3 powerful RCA outputs etc. etc. Pioneer Deh-x9550bt 3-line animated display (192x48 pixels) with color-changeable key illumination. listening music CD input from the back of the front panel Built-in Bluetooth Dual USB input, iPhone / iPod compatible SD card input at the back AUX input at the front 3 x 4 Volt RCA output (front-back-subwoofer) 4x50 watt column outputs 5-band Graphic EQ RDS Radio receiver _______________________________________________________________________ Pioneer Deh-x9550sd Color-changeable 3-line animated display (192x48 pixels) Color-changeable key illumination Mixtrax EZ listening music without pause CD input on the back of the front panel Dual USB input, iPhone / iPod compatible SD card on the back AUX input 3 on the front 4 x Volt RCA output (front-rear-subwo ofer) 4x50 watt column outputs 5-band Graphic EQ RDS Radio receiver ___________________________________________________________________ Pioneer Deh-x8550bt 3-line animated display with color changeover (192x48 pixels) Keypad with color changeover Mix USB input, Mixtrax EZ backside CD input Internal Bluetooth Single USB input, rear iPhone / iPod compatible SD card input AUX input on the front 3 x 4 Volt RCA output (front-back-subwoofer) 4x50 watt column outputs 5-band Graphic EQ RDS Radio receiver ___________________________________________________________________ Pioneer Deh-x7550sd Color changeable 3-line animated display (192x48 pixels Color changeable key illumination Listening to music without mixing with Mixtrax EZ CD input on front panel Single USB input, iPhone / iPod compatible SD card input on back AUX input 3 front 4 Volt RCA output (front-rear-subwoofer) 4x50 watt column outputs 5- band Gra fik EQ RDS Radio receiver ___________________________________________________________________ Pioneer Deh-x6550bt 13-character dot display with color changable and small dot display display on the bottom CD input on the front panel Single Bluetooth input, front, illuminated iPhone / iPod compatible Front panel front AUX input on the side 2 x 2 Volt RCA output (front-back or subwoofer) 4x50 watt column outputs 5-band Graphic EQ RDS Radio receiver _______________________________________________________________________ Pioneer Deh-4550bt White character 12 character dot display screen Blue colored key illumination CD input on front panel Internal Bluetooth Single USB input, front, backlit iPhone / iPod compatible AUX input at the front 2 x 2 Volt RCA output (front-back or subwoofer) 4x50 watt column outputs 5-band Graphic EQ RDS Radio receiver __________________________________________ _____________________________ Pioneer Deh-x3550ui 13-character dot display with color changeover and small dot display display on the bottom CD changable key lighting with Mixtrax EZ streaming music on the front panel CD input on the front panel Single USB input, backlit iPhone / iPod compatible AUX input on the front 2 pieces 2 Volt RCA output (front-back or subwoofer) 4x50 watt column outputs 5-band Graphic EQ RDS Radio receiver
08.05.2020 17:19 # 3
Alicilik
2012-In this series, mixtrax has just begun, the screens are limited animated but very colorful. The USB ports are on the top models again. Very handy with Bluetooth parrot cooperation. Deh-8400bt RDS Radio Receiver CD Player SD Slot (max. 32 Gb) USB Input (2 pcs, at the back) USB to Apple iPhone / iPod Compatible Music Browser (for SD and USB) Internal Bluetooth AUX Input (3.5mm, front 4x50 Watt Column Outputs 3 x 4 Volt RCA Outputs (front-rear-subwoofer) HPF / LPF Frequency Cut Features (50/63/80/100/125 Hz) 5-Band Graphic EQ (100 Hz / 315 Hz / 1) , 25 kHz / 3.15 kHz / 8 kHz) Multi-Color Animated Display (192x48 pixels) Detachable Front Panel Optional Remote Control Deh-6400bt RDS Radio Receiver CD Player SD Slot (max. 32 Gb) USB Input (1 at the back) USB to Apple iPhone / iPod Compatible Internal Bluetooth AUX Input (3.5 mm, on the front) 4x50 Watt Column Outputs 3 Pieces 4 Volt RCA Output (front-rear-subwoofer) HPF / LPF Frequency Cut Features (50/63/80 / 100/125 Hz) 5-Band Graphic EQ (100 Hz / 315 Hz / 1.25 kHz / 3.15 kHz / 8 kHz) Multi-Color Animated Display (192x48 pixels) Detachable Front Panel Optional Remote Control Deh-4400bt RDS Radio Receiver CD Player USB G iris (1 on the front) USB to Apple iPhone / iPod Compatible Internal Bluetooth AUX Input (3.5 mm, on the front) 4x50 Watt Column Outputs 2 pieces 2 Volt RCA Output (front and selectable rear / subwoofer) LPF Frequency Cut Feature (50/63/80/100/125 Hz) 3-Band Graphic EQ (Bass, Mid, Treble) (100 Hz / 1 kHz / 10 kHz) Single Line 12 Character White Backlit Display Red Key Light Illumination Detachable Front Panel Optional Remote command
08.05.2020 17:19 # 4
Alicilik
2011-These series are more polite and simpler in design. Their output is very strong. Some models support SD card. USB ports on the panel. There are not many technical details in this article. Classically 4 * 50w mosfet audio output. at least 1 pair of 4v RCA outputs. Aux and CD feature. It has a restricted bluetooth feature. ** It mentions that there is RDS in the 50's series, but I am using 9350 RDS is no option to be active. Judging by the sound features, the models under 6350sd are not very good. I like 8350sd as a figure. In addition, RDS has been added to 50 series. The 9350sd model may not have RDS. The 4350ub has a wide range of keys and backlight colors. The animated display is only available on the 8350sd and 9350sd models. It has a display of 8350sd 160x48 pixels, 9350sd 192x48 pixels. Deh-9350sd Deh-8350sd Deh-6350sd Deh-5350ub Deh-4350ub Deh-3350ub
08.05.2020 17:19 # 5
error
beautiful topic has been overlooked, when the models are too confused, unfortunately :(
and as someone who is completely confused, what pioneer would you recommend if I say "3r + blutut + usb" and not a cd? Reviews
08.05.2020 17:19 # 6
yenice
[QUOTE = errör] beautiful issue has been overlooked, the models are very confused when there are many, unfortunately :(
and as someone who is completely confused, if I say "3rca + blutut + usb" in one, Which pioneer would you recommend?
I bought 7450sd last year.We decided again with Ali.No bluetooth.I did not include the bluetooth event since I didn't think it would be necessary for me. nice 1 year has never been needed :) cd there but never used. As for usb, there are 2 usb ports on the back of the tape, not on it. 1 cable comes in the box. I put it in the glove box. it was better. there is no usb or something :) I plugged my phone's charger into the other usb port, I pulled it to the torpedo in the same way, which was very useful for me.
In addition, the sd card entry is not outside. CD and SD card inputs are inside when the front panel is opened. so the tape looks very flashy and stylish from the outside. performance is also very good.
I haven't researched the price right now but they gave very low price
http://www.trtuningshop.com/U2890,63,pioneer-deh- 7450-sd-auto-tape-pioneer-pioneer.htm
I bought it for 330 lira.
08.05.2020 17:19 # 7
TuNeR_32
I also bought pioneer deh 7550 mix for my car as a new one, it has a very nice tape usb sd cd aux outputs also there are 3 RCA outputs available in the tape, you have iphone compatible android. the ability to make colors and also mix the music automatically when you press the mix button and the tape bass treble changes color according to the rhythm in the animation.
08.05.2020 17:19 # 8
error
Well, blutut is important, I lost 10 headsets in the car, I don't want to live without eyes on the police with my uncle & nbsp; I don't want to live with eyes anymore & nbsp;
it would be nice if it was not a cd. .
these types of eared models are nice, in fact, let me look at these eared models.
< img src = "http://www.trtuningshop.com/FB,5895,28,pioneer-deh-7450-sd-oto-teyp-pioneer-pioneer.jpg" height = "186" width = "500" border = "0" />
errör 2013-09-03 21:39:30
08.05.2020 17:19 # 9
yenice
[QUOTE = errör] Well, blutut is important, I lost 10 blut headphones in the car. I don't want to live with my uncle & nbsp; without eyes anymore & nbsp;
nice to have a cd I haven't touched the CD in my hand for years.
these type of eared models are nice, actually let me look at these eared models.
this is already my tape model. it is really very stylish and featured. but i don't know the bluetooth event. do you have these types
08.05.2020 17:19 # 10
Alicilik
If the gentlemen says BT at the end of the models, it is bluetooth. Especially, he talks about it.
9550BT is your favoir.
08.05.2020 17:19 # 11
yenice
[QUOTE = Receiving] If gentlemen write BT at the end of the models, it is bluetooth. Especially, he talks about it.
9550BT is my favoir.
9550bt is the same model as my tape. I think there is an additional bluetooth. If there are people who say that bluetooth is indispensable, these types of tapes are good both in terms of performance and appearance. but the prices seemed quite salty to me. last year i bought 330 lira, i looked where i bought they gave 400 lira price. Reviews
08.05.2020 17:19 # 12
Alicilik
The dollar has increased :(
08.05.2020 17:19 # 13
error
How about this set?
http://www.hepsiburada.com/liste/productDetails.aspx?productId=otpiotsg1722i&categoryId=26090
http://www.hepsiburada.com/liste/productdetails.aspx?productıd=otpiotsg1344r&categoryıd=26090
Reviews
http: //www.hepsibura .com / list / productDetails.aspx? productId = otpiotss20 & amp; categoryId = 26090
I'm thinking of embedding tweets in the original slot
< i>
sub clean second hand, I'll buy it from a friend
"Quest
