pioneer tape connector
08.05.2020 17:07 # 1
megez
Hello friends. I connected the pioneer 5250 sd tape to my car, but after I connected it, the clock indication and the message that the doors are open are still donuyo. Do I have a chance to activate the steering control.
08.05.2020 17:07 # 2
Quiksilver_106
I used it from that model, it is a really nice and high quality tape .. but I can't say anything about the fault
08.05.2020 17:07 # 3
206206
insert the plus pole of the brother battery and fix it
08.05.2020 17:07 # 4
Alicilik
To reset the bsi,
Open the window of the right front door of the vehicle. Turn off anything that will draw electricity in the vehicle. Open the hood.
Get off the vehicle with the key attached to the ignition. Close the door. Wait for 3 minutes.
Then remove the battery terminal and wait another 1 minute. Install the battery terminal. After half a minute, turn on the headlights without opening the door.
I learned from the brother of Cenker.
The same problem happened to me too but everything was solved when I got 3 lines of screen
08.05.2020 17:07 # 5
[QUOTE = Retrieval] To reset the Bsi,
I also learned from Cenker brother that the vehicle adapts the new equipment.
The same problem happened to me but everything was solved when I displayed 3 lines
I think the 3 minute rule for right-hand drive vehicles Confusion with. Otherwise, it will be a little difficult to light up the headlights without opening the right ten windows.
I have shared the 3 minute rule in a title before.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=20338&title=aku-kutup-baslarini-sokerken-3-dakika-kural
08.05.2020 17:07 # 6
Alicilik
[QUOTE = koliva]
I think there was a confusion with the 3-minute rule for right-hand drive vehicles. Otherwise, it will be a little difficult to light up the headlights without opening the right ten windows.
[/ QUOTE ]
"LOL"
Brother I haven't done military service yet I have a right left problem, sorry!
08.05.2020 17:07 # 7
megez
thanks guys i will try when i find time
08.05.2020 17:07 # 8
megez
So does the tape that I gave this model have a connection to the steering wheel control?
08.05.2020 17:07 # 9
Alicilik
how many models are your vehicle?
08.05.2020 17:07 # 10
megez
2003 model
08.05.2020 17:07 # 11
gozem
Unable to connect the steering wheel because your tape does not have a w / r output .. unfortunately, Pioneer's models with double zero ending have this output
08.05.2020 17:07 # 12
Alicilik
[QUOTE = eye] Unable to connect the steering wheel because your tape does not have a w / r output. Unfortunately .. pioneer's models with double zero ending have this output [/ QUOTE]
W_R input is just too not available on older models, nothing to do with model code. You got this information wrong. I am using 9350 [TUBE] 3nwfwToUQqg [/ TUBE] [TUBE] K_fAJd_Qadk [/ TUBE]
is also the remote next to the 50s series. These controls do not end with 00 series.
In 2003, the joystick has 10 functions. The cherno35 nickel arm makes it compatible with the tape at a very affordable price. If you take a look at the videos (my shot is all), it is simple to do the control, but it takes a little bit of manual work.
Or you can bring the part that I use from abroad to around 100 TL.
08.05.2020 17:07 # 13
tellotello
[QUOTE = Receiveness] [QUOTE = eye] The steering wheel cannot be connected because your tape does not have a w / r output. Unfortunately .. pioneer's models with double zero ending have this output [/ QUOTE]
The W_R entry is not only found on very old models, it has nothing to do with the model code. You got this information wrong. I use 9350. There is also a remote control next to the 50s series. These controls do not end with 00 series.
Or you can bring the piece that I use from abroad around 100TL. Does the vehicle turn off the tape when it goes to economy mode? I think this feature is very logical and if it is useful, I ask for it. Thank you. & Nbsp;
08.05.2020 17:07 # 14
Alicilik
[QUOTE = tellotello]
Ali Hodja, forgive me if you said in the video and I missed it; Does the vehicle turn off the tape when it goes to economy mode? I think this feature is very logical and if it is useful, I ask for it. Thank you. & Nbsp;
It is independent to economy mode but becomes dependent on BSI.
You have opened the tape for the first time and listened. If you did not make the connections wrong, you closed the anthem with the tape open. The tape continues to run. The 15-minute fln is running, at that time the vehicle switches to economy mode, but the tape continues. It turns off on the tape after 5-6 minutes. It certainly doesn't turn on like in Economy mode. Taaki until you open the key or open the door.
Or you removed the tape open key and got out of the car. The tape is working. You locked the door, it still works. After 50-60s, the tape is closed. It does not open from the inside. (it works like a turbotimer "Big)
If you open the tool in this way, it starts working on the tape. Friends how surprised are they? Reviews & nbsp; Member
08.05.2020 17:07 # 15
megez
brother tape just like you described, after the contact is closed, the tape turns off and there is a w_r input behind the tape.
08.05.2020 17:07 # 16
Rebel35
hello,
steering & nbsp; for tape handle & nbsp; how can we reach the master in izmir, I would be glad if you help,
08.05.2020 17:07 # 17
Alicilik
[QUOTE = Rebel35]
hello,
steering & nbsp; for the tape handle & nbsp; how can we reach the master in izmir, I would be glad if you help,
cherno35 itself.
There was a number but I can't find it.
08.05.2020 17:07 # 18
hsnsnl
Hodja, how can we make the connection?
08.05.2020 17:07 # 19
tellotello
I think you do not intervene, take it from the apparatus sold on ebay or something, you just activate the joystick by removing it. I just bought it, it came from England within 15 days.
08.05.2020 17:07 # 20
hsnsnl
[QUOTE = tellotello] I think you do not intervene from the apparatus sold on ebay or something, you just activate the joystick by removing it. I just bought it, it came from England in 15 days. [/ QUOTE]
how much it cost as a price
Page : / 2
