Pioneer Installation Suggestion?
08.05.2020 18:15 # 1
Piyanist89
Sa Friends Now I have 206 vehicles and I removed the tape on it and created a small installation.
1 Set JBL GT-650C Mid Kit
Jvc Cd Player Tape
38 Cm Pioneer Champion Series Bass
Ediosan 505 a 5 Channel Amp
I have a problem. This is the Jbl Sub Series, I guess I didn't like the sound. The trebles are ridiculous and the voices don't come alive. Is there any mid team that you can recommend except for JBL? Pioneerin Mid Team Is Not Much In The Market.
2. My Question Is This. One Mid Team at the Front and 1 Set Oval Column At First If the sound is not enough, I can put the 2nd Team. This Oval Column Must Be A Pioneer Because I Like The Pioneer Sound. I have in mind the Old Series Ts 6985. I found the old version on the internet for 150 TL and sell for 350 TL. What is the market for this now? Is there a problem in my 150 seller who says 350, 150? Apart from this, they recommend the Pioneer TS-6965v2 in the series released by Pioneer. Does anyone use this model?
I want ts-s20 as a high-pitched version. Is there a difference between 150 TL and 150 TL in the new version?
There is no exact price as a budget. I will not take all of them as a team.
08.05.2020 18:15 # 2
barishrocker
I think it is enough to replace the front stomachs with infinity ref 6500cx and get a pioneer oval. Also, there is no need for treble. If the rca output number on the tape is low, the voltage is dividing. Mids can also steal lifeless from it. You have to look at the settings and the connection ..
08.05.2020 18:15 # 3
Piyanist89
I understand. I think he might be in the amphitheater. I had a car that was born 2 years ago, it was due to the amplification of Ozmn jbl. the voice is disrupting in the 25's. i am infinity too. I usually listen to arabesque though not as much as before. i listen to pop trance france i listen any style anyway
08.05.2020 18:15 # 4
barishrocker
If there is distortion in the sound, it can be from the amp as you said. Also, the number of amp outputs on the tape must be at least 2 pairs. There may also be a problem. If I am available, I will look into the properties. Rca passes as pre out.
08.05.2020 18:15 # 5
Piyanist89
Tape jvc kd-r305 model back picture
http://www.azvuk.ua/upload/gallery/wm_6f85cac89a0c40716d5d09c906ca9c3f.jpg
08.05.2020 18:15 # 6
EmSul
You have to change your mid team and also a weak anfi is insufficient in your anfiles. Old pioneer 6985 has no joke plus. and I suggest a better amplifier, I wouldn't recommend putting another speaker on the back, or even a good mid team 1 pair is more than enough, but whatever it is is that our people would buy 2 sets of poor quality for that money rather than getting a good quality stomach. First, change a mid team, you did not like it again, you will change your amplifier.
08.05.2020 18:15 # 7
Piyanist89
Well, do you think I can wear infinity 6500 as my mid jewelry? Now the administration is not mine, your friend had come while buying a car. I will change it in the future. If I take the speaker well, I will buy tapes and amps in the future and the quality will increase one more time. I am a tight speaker in my hand and it is not a plus for his amp to be good.
08.05.2020 18:15 # 8
Piyanist89
As a result, there should be a sound behind. I go out of the car, it just comes from the front, when I pass your car all over it, you should hear the sound. let some quality sound out. of course it is more important to be inside.
08.05.2020 18:15 # 9
EmSul
I do not recommend the reference series of infinity, they are not successful according to the price and the treble-weighted players Hertz old series or mtx blackthunder series are successful components in price performance. would
08.05.2020 18:15 # 10
barishrocker
If the amplifier is to be changed, hertz can be taken old, but the amplifier should be stronger. I said infinity according to edison amp and strong treble request. The price was very reasonable too, but I don't know what happened after the dollar increase.
08.05.2020 18:15 # 11
barishrocker
I could not reach the RCA pre-out information about the tape. I looked a little, but there are always pages written in different alphabets. If there is only one RCA, the quality decreases from it.
08.05.2020 18:15 # 12
Piyanist89
what are the terms in these amp features so can you explain it to my amp
4 ohm rms load 50wx4 + 150wx1
2 ohm load 150wx4 + 200wx1
4 ohm bridget 350wx2 + 200wx1
these are writing. rms load what is load what is bridget? eg, '. I can connect 4 50-watt rms columns in 4 ohm rms or I need to connect 1 set 200-watt column by saying 50 * 4? If I put more watts, won't it? I could not solve this kind of information on the internet.
08.05.2020 18:15 # 13
barishrocker
Each speaker has an ohms value. There are also the rms powers they want. It's sometimes called nominal power. You can install 2 sets of speakers in the amplifier's stereo channel that requires around 50w rms. By the way, the max power of the speaker you call 200w. So you will look at the rms power.
I think you get the pioneer analogy as the first job if you can afford it x7550 or x8550; If it is not enough, buy x5550 at least. Kenwood also goes on sale. You will also need to pull the RCA cable again.
Then you get to the back from the same mid-team or oval speakers. There will be a lot of difference.
08.05.2020 18:15 # 14
Piyanist89
I understand that all the crime is not in the mid team :)
08.05.2020 18:16 # 15
Piyanist89
They did not remove the original treble of the car while wearing it, both the mid and the treble are working. One of my old plumber broke the originals out of the high-pitched treble, he said.
08.05.2020 18:16 # 16
barishrocker
Of course it also spoils. You change your plumber too JBL is not a very good mid, but if you can make it sound, it should sound above average. Jbl soft player is a little bit more pioneer than bass. So it is a little crushed but it is okay with proper connection. I think if you change your mainunit, there will be some improvement in the system. If you attach the same mid-team to the doors instead of the oval, you will get a cleaner proportioned sound. The amp is also inadequate, but the tape change of the priority. When the tape changes
If you buy 7550 or 8550, cut 3 pairs of RCA cables. If you get 5550, 2 pairs of RCA will be drawn. Do not forget this;) Maybe you don't even need to change the amp, it will satisfy you.
08.05.2020 18:16 # 17
Piyanist89
I do not have a plumber, I consulted the idea that this car was installed by my father's friend. I said that I would listen to it from my own speaker. I would do it with what I have. Actually, the sound system would not work one by one. As I did at the moment, it would be better to collect money as one and two months later, and all of them would be better. you choose it accordingly. Anyway, I am not a person who loves bass very much, but of course, but it will hit the bottom one by one that will not bummmmmmm feed it. I don't like the current pioneer bass. Repentance to Pioneer Bass. The sound system I want is actually an acoustic in the original system in these new cars. The sound sounds very clean and bright. I prefer tre 'without any exaggeration instead of something bass. For some reason, I do not know if the sound in this pioneer's old oval columns is very beautiful, slow arabesque. I have a tss 20 somewhere, if the original gives me the price I want, I will jump to the top ten before the column tape. the old one is very difficult. You got this tape business in mind. I think the tape does not play a big role, it strengthens it because it is an amp. let me investigate the models you say
08.05.2020 18:16 # 18
barishrocker
You are my own about bass. Then I suggest you have the re audio rex8 d4 in it when you go;)
08.05.2020 18:16 # 19
barishrocker
You need to take it well because it is an anatomy that plays music.
08.05.2020 18:16 # 20
Piyanist89
I have heard the bass you suggested a few times, I take note of what they say. If I lighten the limit of the credit card, I will not get all of them at once. prices almost the same?
Page : / 2
