pıoneer ındech help please
08.05.2020 17:40 # 1
soner09
Hello friends, I have the poneer Indech in my car. For example, you have the song playing in the tub
I want to listen and watch it on both the audio and the screen in my car, but I couldn't do it.
08.05.2020 17:40 # 2
hsnsnl
You can not run from USB teacher, try the videos on CD.
08.05.2020 17:40 # 3
soner09
How do I make a cd?
08.05.2020 17:40 # 4
hsnsnl
2-3 DVD settings can now be printed on the DVD.
08.05.2020 17:40 # 5
soner09
bro do you have any format?
or know the conversion program
08.05.2020 17:40 # 6
Aziz
I understand you have a DIV player. as far as i know it has been mp4 feature
I tell you what you have to do.
youtube tan to the address of the video in the address bar
for example
While watching, you will be directed to another page where you can download the video (adding 2 small letters S) to www.yotube.
If you choose the option that suits your resolution (those marked with red at the bottom, which means the formats and resolutions that can be downloaded), download it and try it with a flash disk.
Don't play with codec or resolution will be 70%.
2 steps without
You will find nero multi media 10 and install it on your pc originally, and you can do it from there, codecleme etc are all available.
08.05.2020 17:40 # 7
soner09
I'll try, brother, thank you for your help
08.05.2020 17:40 # 8
Aziz
Did you try it, thanks?
08.05.2020 17:40 # 9
soner09
DENDEIM BUT NOT HAPPENED :(
08.05.2020 17:40 # 10
howard
You are downloading divx converter, my brother, you are throwing the format to usb at the lowest level as I showed in the picture
howard 2013-06-10 12:32:51
08.05.2020 17:40 # 11
soner09
OK SIMDI IDIRIOM KARDESIM
08.05.2020 17:40 # 12
howard
[QUOTE = soner09] OK IT IS IDIRIOM KARDESIM
Let me know when you do, it doesn't have to be a luxury. There are many types of players that it supports in the user manual, it says blueray mp3.mp4 or something, but the Turks never read Cem YILMAZ says either there is not much manual in Turkish, it just comes to an end and it comes to my mind. Big smileBig smileBig smile
howard 2013-06-10 12:55:03
08.05.2020 17:40 # 13
soner09
KARDES SHOULD LIKE HIS LINK WHERE TO DOWNLOAD YOU
08.05.2020 17:40 # 14
howard
http://www.divx.com/
in the top right it says free download in yellow.
08.05.2020 17:40 # 15
sboz
Hello.
I researched quite a bit in time. Do not deal with DVD or something. You can easily watch from USB flash memory.
-First of all, the video you will download should not be higher than 360p because freezing happens while watching.
- Download Firefox and install the youtube video downloader plugin.
-When you install the plugin, click the download option at the bottom of the video you watch and select the 360p one.
Download Video Aiseesoft Total Video Converter and convert it to DivX.
-Take it on your flash memory.
I also use pioneer indash. I tried very hard on time. I can watch video clips without any problems.
08.05.2020 17:40 # 16
soner09
Walla I couldn't do this :)
08.05.2020 17:40 # 17
Aziz
You go to step 2 I said, all your troubles will pass :)
08.05.2020 17:40 # 18
sboz
What is the part you can not do? Let me explain in more detail.There are no videos that other video converters convert.I did a lot of work.
sboz 2013-06-10 18:03:14
08.05.2020 17:40 # 19
howard
brother, what music do you want? I download it and do it to you: D close this event :) I took a picture to you. Take me to the car at flasha watch: D howard 2013-06-10 20:17:35
08.05.2020 17:40 # 20
soner09
THE FRIENDS HAVE MADE ANYTHING YOU WANTED GENE OLMUYO GENE OLMUYO NO AUDIO DIO AT THE END, I FIRST BITANE THE TAPE :)
Page : / 2
