Pıoneer DEH-2300
08.05.2020 16:22 # 1
ßaris
friends i'm thinking of taking the pioneer deh-2300. a mono amp + cabinet sub. + mid team will be connected, how does it work? I would be glad if you help me, I will buy it tomorrow.
08.05.2020 16:22 # 2
gozem
I know that tape's amp output is low, see a slightly higher model
08.05.2020 16:22 # 3
ßaris
Come on, what do you suggest?
08.05.2020 16:22 # 4
gozem
Option is very much, but of course limited to your budget, I think I recommend the deh-p85 model 2 amplifier output with blutoot + 1 sub sub output has 1 output in 4volt power price, but it should be around 400tl
08.05.2020 16:22 # 5
ßaris
I can give around 250-280 at most.
08.05.2020 16:22 # 6
gozem
The brain of the installation is analogy, if your aim is not to establish a professional installation, it will sound enough to satisfy your option.
08.05.2020 16:22 # 7
[QUOTE = eye] I know that the tape's output volt is low. See a slightly higher model [/ QUOTE]
Hodja, there is no output volt. The wattage you mentioned. So the output power is "Wink" The terms are small but their meaning is very different.
08.05.2020 16:22 # 8
ßaris
A professional installation is not a bass sound that is important to me. a 38 'sub with cabin. + a mono amplifier to feed + a mid team to manage? Can you suggest a tape for this? Wouldn't a tape recorder between 200-300 rubles work for me?
08.05.2020 16:22 # 9
gozem
Don't hang out with fine details, everybody understands what I mean
08.05.2020 16:22 # 10
ßaris
[QUOTE = koliva] [QUOTE = eye] I know that the tape's amp output vol is low. See a slightly higher model [/ QUOTE]
[/ QUOTE] if you help my question :)
08.05.2020 16:22 # 11
gozem
Barış, I think, do not deal with mono amplifiers, my advice is 5 or 6 channels (my advice is 6 channels jbl 755,6), the price of the amplifier is a little salty, but don't worry, don't worry, 2 channels of the 755.6 model sub output, bridging those channels and 30, luk or 38 middle class sub. Connect to (kicker cvr 15 or jbl 1100). If you don't bump into the other 2 channels in the oval and 2 channels in the middle, I will buy it from you at the price you get. border = "0" align = "middle" />
08.05.2020 16:22 # 12
ßaris
You are right, but if I do not get stomach amps (I do not know if I am going to be), as I said I will be connected directly to tape or mono amps, bass sound is not important for me. I am someone who has dismantled 4 + 5 of 5 + 1 and listened to the press. My purpose is that when I sit in the car, I do not need a bass sound that will make my seats shake me. Sub. As Kicker cvr 15 - DD 1512 I am going to buy one of them, a mono amplifier and a tape.
08.05.2020 16:22 # 13
gozem
What does Midler work without sound, but it does not sound, it does not happen with mono amplifier
You connect 2 channels sub.a and 2 channels mid.e.
I am now running the cvr 12 on 2 channels 12
poneer oval on the other 2 channels
http://www.sahibinden.com/ilan/alisveris-elektronik-arac-elektronigi-4-kanal-stereo-cok-kanalli-anfi-64388569/detay/ my eye 2011-11-17 16:43:10
08.05.2020 16:22 # 14
tolga35
dear koliva, the amplifier of the tape that friends talk about. The output voltage affects the sound quality in these types of outputs, and these outputs can only be connected to the amplifier, they do not sound through the normal speaker; however, the power value of the power outputs of the tape is wattage as you say ...
08.05.2020 16:22 # 15
ßaris
confused me :) I told you the system in my head, tell your advice.
Subwoofer: Kicker cvr 15 or DD 1512 (1 unit with cabinet) I'll choose it according to mono (1 piece of mono).
08.05.2020 16:22 # 16
gozem
Peace, as you have attached, you will get a high model analogue in the first message /// as I wrote to you, you will connect that output with a sub bass output to the mono amphitheater.
08.05.2020 16:22 # 17
ßaris
okay or we'll look at you anyway :)
08.05.2020 16:22 # 18
musictime
If you can give it 250-280, take it from my tape 6350sd pioneer it had 2300deh five cents, I gave it to my father.
08.05.2020 16:22 # 19
ßaris
I know 6350 I was going to get it first but I did not know. hm so how are you satisfied? Will it work for me?
08.05.2020 16:22 # 20
musictime
would be naughty, a crazy device with 3 outputs 4 pieces of 94 es pioneer kicker cvr 400rms of 30 and 5 channels of skytech anfim I can get the sound to 62)) no click
Page : / 3
