PIONEER |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 17:55 | # 1 |
I WANT TO GET A QUALITY EFFICIENT SOUND THIS SYSTEM IS SUITABLE http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-paket-sistem-pioneer-dxt-1569-ub-teyp-ve-2-takim-hoparlor-seti- 129436878 / detail / CAN I RECEIVE THIS QUALITY AND HIGH SOUND IF I TAKE IT BASS + AMP IN THE FORWARD? OR WHAT ARE YOUR RECOMMENDATIONS |
| 08.05.2020 17:55 | # 2 |
Alicilik |
Hodja system is installed on every tape. According to the quality of the tape, your yield will be more or less. When looking at tapes, if possible, look for 2 RCA outlets. There is only one output on this tape. Also, I saw this model now, normally tape prices are interesting to me for this package price. Corsa B is already a small vehicle, even medium coaxes are enough for you. |
| 08.05.2020 17:55 | # 3 |
What do you mean when you say RCA output, what does it do and master. |
| 08.05.2020 17:55 | # 4 |
Alicilik |
[QUOTE = berkejack1] What you mean by RCA is what you mean, what does it do. [/ QUOTE] RCA is a socket type. This is a 3-socket RCA with this yellow-red-white cable that connects equipment like television dvd vcd. Tetypte outputs a low voltage audio signal from this socket. This signal goes to the amplifier with an insulated cable and amplifies it to the speaker. There are RCA inputs like tape recorders, as I mentioned. These inputs support a specific range of volts. Therefore, you cannot connect the direct speaker output of the tape. There are apparatus that converts this to the Low voltage RCA with an apparatus connected to the normal output, if there is no RCA output of the tape. The sound unit plays a major role in sound quality because the first signal will come out of it, the amp to mix it, and the intermediate eq if available. It will be. A powerful RCA output (3-4 v) is a very difficult but gold plated, quality RCA cable will be a nice way to amp. |
| 08.05.2020 17:55 | # 5 |
Is there a tape that you can recommend with 2 RCA outputs, I prefer it to be a brand like pioneer, jvc at an affordable price. |
| 08.05.2020 17:55 | # 6 |
Alicilik |
pioneer also goes up to 2 after 4000 series if I'm not mistaken. Except for Pioneerda P series, the RCA outputs are 4V. Depending on the model, some features and the number of outputs vary. If there is a model you like, switch to it. I have no idea about JVC |
| 08.05.2020 17:55 | # 7 |
well thank you outside the tape how do you think the other oval and door hoporlors |
| 08.05.2020 17:55 | # 8 |
Alicilik |
it works, but you have to listen to it without turning up the volume too much.
| 08.05.2020 17:55 | # 9 |
why does it make you wheeze |
| 08.05.2020 17:55 | # 10 |
Alicilik |
Why does [QUOTE = berkejack1] make it shimmer [/ QUOTE] Pioneers are 62 levels, after 50, they distort the sound |
| 08.05.2020 17:55 | # 11 |
Do you have any suggestions for the door and luggage |
| 08.05.2020 17:55 | # 12 |
THAT IS THOUGHT A SET THAT DO YOU HAVE GOOD AND SUITABLE COMPATIBILITY TO EACH OTHER? BAGAJA: Pıoneer TS-A6995S Oval Speaker 600Watt Auto Fashion DOOR: PIONEER TS-G1721i 17CM DOUBLE CONE SPEAKER 230W TAPE: Pioneer DEH- 4550 BT |
| 08.05.2020 17:55 | # 13 |
Alicilik |
[QUOTE = berkejack1] THAT I HAVE THINKED A SET THAT DOES GOOD AND SUITABLE COMPATIBILITY TO EACH OTHER? BAGAJA: Pıoneer TS-A6995S Oval Speaker 600Watt Auto Fashion DOOR: PIONEER TS-G1721i 17CM DOUBLE CONE SPEAKER 230W TAPE: Pioneer DEH- 4550 BT [/ QUOTE] Your choices are very nice, but you cannot get the performance of the parts unless there is an amp. The oval 6995 100w RMS speaker of your choice is the output of your tape 24w rms. Compensants are more compatible than ovals.
| 08.05.2020 17:55 | # 14 |
I have no knowledge of what's happening. HOW MUCH WATTLIC BI AMP OVALLER 600 + 600 = 1200 WATT 230 + 230 = 460 in those for the door I HAVE TWEETER POWDER 200 + 200 WATTA IT'S ROOM 400 (PİONEER TS-S20 TITANIUM DOME TWEETER) DO I NEED AN AMP OF 2060 WATTLES? |
| 08.05.2020 17:55 | # 15 |
Alicilik |
Sir, before I go into much detail, I will make a brief explanation and you should make your searches accordingly. There are 3 values to know in the first stage of the amp; Peak power RMS power impedance Watt values that you mentioned are peak values. I say don't take these too much into consideration. The main values are impedance and RMS values. For example, 6995s can perform 600w peak (also called MAX) 100w RMS (nominal) at 4ohm impedance. The amp you need to use for your ovals should be higher than 60w rms at 4 ohms so that you can get efficiency from them. The same goes for the door speakers. Loudspeaker systems with a strong and medium sound frequency capability, which we call component. Generally, there are 2-way systems on the market. It is an intentional (mid and treble) woofer (13-16cm) and a tweeter in two ways. There is also a crossover bridge to separate them. Why will you need a tweeter in this system? 6995 5 way Already tweeted in 1721 Be careful while buying the products you want to buy, but there are too many fake versions. Pioneer 6500 amps can be preferred for the brand integrity of the parts.
| 08.05.2020 17:55 | # 16 |
I saw the need for a tweeter, perhaps because the sound was low. By the way, my doors are 16 cm and I replace them with Pioneer TS-G1614R 16cm 230 W Natural Cone SpeakerDO YOU HAVE ENOUGH AS THE AMP? http://urun.gittigidiyor.com/garaj/jameson-usa-604-4kanal-1500w-amfi-sifir-garanti-92725292 |
| 08.05.2020 17:55 | # 17 |
or that product? http://urun.gittigidiyor.com/garaj/piranha-shockpower-s-type-3200w-oto-anfi-4-kanal-92145866 or is there any product you can recommend |
| 08.05.2020 17:55 | # 18 |
Alicilik |
[QUOTE = berkejack1] maybe I needed a tweeter because the sound is low. By the way, my doors are 16 cm and I replace them with Pioneer TS-G1614R 16cm 230 W Natural Cone SpeakerDO YOU HAVE ENOUGH AS THE AMP? http://urun.gittigidiyor.com/garaj/jameson-usa-604-4kanal-1500w-amfi-sifir-garanti-92725292 [/ QUOTE] Do not be afraid to the front doors 160-165-170mm will be all. I prefer 1721. Even though Jameson hurts, an indelible brand works. |
| 08.05.2020 17:55 | # 19 |
WHOLE MASTER BAGAJA: Pıoneer TS-A6995S Oval Speaker 600Watt Auto Fashion DOOR: PIONEER TS-G1721i 17CM DOUBLE CONE SPEAKER 230W TAPE: Pioneer DEH- 4550 BT AMP: JAMESON USA -604 4KANAL 1500W AMP ZERO THIS SET FITS EACH OTHER AND I AM GOOD QUALITY AND HIGH SOUND WHICH MAKES THE INSIDE OF THE CAR? |
| 08.05.2020 17:55 | # 20 |
Alicilik |
Sir, I misunderstood 1 minute 1721. That one way me I mixed it with 172. http://urun.gittigidiyor.com/garaj/pioneer-ts-g172ci-17-cm-mid-komponent-bass-taki-89578510 "> http://urun.gittigidiyor.com/garaj/pioneer-ts-g172ci -17-cm mid-bass-component-Taki-89578510 |
