Piling in 2nd Gear (No gas eating)
08.05.2020 14:01 # 1
MertCakbak
My vehicle's battery ran out of time, I removed the bass, and it remained, and naturally the remaining chlormeter counter was reset, but this is not my problem. do you think the problem might be from the avas settings like where i think (the possibility of the brain being reset when the battery changes)
I'm going to go into maintenance this week though, but if we find an answer here, at least the information here is a reference to our other users who have problems
Thanks
(Peugeot 106 Quicksilver)
08.05.2020 14:01 # 2
Our friends who use 106 quik will be helpful .. but I think the air filter may be broken.
08.05.2020 14:01 # 3
hasimayaz
There is no advance adjustment on the Ecu lu vehicle .. Since permanent settings are stored on the rum, the ecu information is not deleted by removing the battery.
First of all, air filter replacement and throttle cleaning should be done. you can review the following article:
then the spark plug and spark plug cable should be checked.
08.05.2020 14:01 # 4
sinan-s
I agree with Hashem evening dress
08.05.2020 14:01 # 5
haruncoskun
I think it has spark plug cables
08.05.2020 14:01 # 6
MertCakbak
Thank you very much for your answers. When I went to maintenance this week, I made checks in line with your recommendations and I will be able to see the results.
08.05.2020 14:01 # 7
MertCakbak
Thanks for your help. Has there been a device that adjusts the idling in the throttle?
08.05.2020 14:01 # 8
[QUOTE = MertCakbak] Thanks for your help. Is there a device that adjusts the idling in the throttle butterfly? I have a problem with it.
nice to solve the problem ..
08.05.2020 14:01 # 9
hasimayaz
idle valve or also regulator ..
08.05.2020 14:01 # 10
Rfk
glad that the problem is solved
08.05.2020 14:01 # 11
t@lip
First of all I am glad that your problem is solved. My vehicle (2004 206 X-line) had the same problem, so it did not collect vehicles in 2 gears and was stacked. Manifold pressure sensor malfunction. I had given 25-30 YTL. After the part changed, the performance of the vehicle increased in all gears and its fuel decreased. Talip_019 2009-06-02 15:12:21
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
