(pictured) I installed the trip computer
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 17:00 # 1
yenice
Hello. I just installed the trip computer. but I think the information is not correct. the information appeared on the screen but it seems wrong. & nbsp; Due to the pictures, the image looks bad but there is no problem. The screen is solid. all screen photos are as follows:
I guess this is range
I think this is the service mileage but it says 9200km on its indicator.
I don't know this ..
this car is also stationary when driving. At first I thought the speedometer but it does not change. but it writes the unit in km / h. that means speed. therefore I think it shows the information wrong.
hour date has no problem
door open indicator, all works on the doors, but does not react on the right front door.
< br>
08.05.2020 17:00 # 2
Alicilik
Now that I haven't seen the right front door in the message, I noticed. & Nbsp; A different situation. When you try to open the door from the outside after locking the door, does it open?
08.05.2020 17:00 # 3
With the ignition on, hold the button on the tip of the wiper down and let the data be reset.
08.05.2020 17:00 # 4
cerci07
good luck in the fourth picture, you have used the vehicle at the time after the reset, that is, you have used 37 km / h speed average in the second picture.
08.05.2020 17:00 # 5
Serkan
The information in the second picture shows the km traveled after resetting the trip computer, after resetting the trip computer in the 3rd picture, it shows the average fuel it consumes 100 km, in the 4th picture it shows the average speed after the trip computer was reset.
08.05.2020 17:00 # 6
metin
Good luck, & nbsp;
Only the outside temperature display remains. Our Memotech friend made it with pictures. I recommend you to review this topic. nofollow "> http://forum.peugeotturkey.com/forum_posts.asp?TID=13436&title=206-xline-d-scaklk-gstergesi
08.05.2020 17:00 # 7
yenice
Thank you guys for the information, then there is no problem.
I could not reset the trip computer by pressing the wiper key. I held it down for about 1 minute. I started the car and stepped again. First I opened the ignition and then started it again. then I removed the socket of the trip computer and reinstalled it.
I have only one temperature sensor left now. I searched for a few days, I also searched for spikes, but I couldn't find it.
They said we have forum sponsors with the mirror. They said the sensor on the mirror. however, it was said that the spare parts sites I found on the internet would not be above the mirror. so I'm confused.
I don't know if my existing mirrors are electric, there is a dotted dot on the left side of my left mirror. I never looked at it. What good does it have for me? I did not change them both electrically, both the sensor comes on, if it happens ..
yenice 2012-08-24 00:51:29 < / edited>
08.05.2020 17:00 # 8
yenice
I also noticed that at the right door, when I open the right door, the top lamp does not come on and the door open warning does not appear on the trip computer. There is no problem on my other doors, both the top lamp is on and the paper on warning appears on the trip computer.
08.05.2020 17:00 # 9
individual
Hello,
Is the vehicle connected to the computer in the service?
It may be necessary to introduce the trip computer.
Maybe it is not reset because of this.
When you open the door, you said the ceiling lamp is not lit.
The data on the screen is very good. The distance traveled after the last reset, which says km. 9999 is already final.
5.0 lt is the average fuel consumption per 100 km.
37 kmh is the average speed you made after the last reset.
I also have an instant consumption. When that line comes out. When the 30 km speed is over, it starts showing value.
individual 2012-08-24 02:13:35
08.05.2020 17:00 # 10
yenice
[QUOTE = individual] Hello,
Is the car connected to the computer in the service?
Maybe this is not reset.
The door switch of the problematic door is broken.
174 km, the estimated route to go with the gas in the tank at the moment,
9999 km after the last reset distance traveled. 9999 is already final.
5.0 lt, average fuel consumption per 100 km.
37 kmh, average speed after the last reset.
I have an instant consumption. When that line comes out. When the 30 km speed is over, it starts to show value.
What exactly is the part you call the door switch? Is it possible to repair or something new or should I buy it?
I thought it might have been a socket plug on the door because the top lamp did not come on when the right front door was opened and did not appear on the trip computer. We will remove the door tomorrow, there is no other remedy.
08.05.2020 17:00 # 11
individual
The button on the door pillar, which I call the door switch, understands whether the door is open or closed.
08.05.2020 17:00 # 12
yenice
[QUOTE = individual] I call the door switch, the button on the door pillar that understands whether the door is open or closed. [/ QUOTE]
I looked at the door post, but I couldn't see anything. Or I couldn't see because I didn't know what to look for. I looked for something like that but I couldn't find it.
08.05.2020 17:00 # 13
yenice
[QUOTE = text] Good luck, & nbsp;
I was trying to provide the sensor for this. I searched for all spare parts and printers for pages. I couldn't find it alone in any of them. They said it was with the mirror. I think it was on heated mirrors. but side industry mirrors. my own mirrors are original so I didn't want to buy a mirror.
today I found the sensor for 40 lira. they removed it from the mirror and sent it. it probably remains on Monday. I'll put the picture again.
08.05.2020 17:00 # 14
yenice
the sensor has arrived today. we connected the cables as below but it didn't work.
cables that we cut and connect the sensor:
cables and sockets with which the sensor comes with. if anyone wants.
08.05.2020 17:00 # 15
kadir32
slm brother got my 2003 model 206 hdi x-line tool & nbsp; 3 line screen. But neither in the service nor the electrician could not find the cable to connect the heat sensor from bsi or the brain. I even bought a sensor and attached it to the mirror. but no results. they don't know either. or they don't want to bother. & nbsp;
08.05.2020 17:00 # 16
gngburak
[QUOTE = yenice] sensor came today. we connected the cables as below but it didn't work.
the cables we cut and connect the sensor:
cables and sockets with which the sensor comes.
[/ QUOTE] I couldn't understand my piece temperature sensor as an assignment for my door sensor as an assignment gngburak 2013-01-27 16:05:56
08.05.2020 17:00 # 17
Ahmet206
Big red writings have closed the subject :)
I need a temperature sensor. Help ...
