Pevgeout dating 2.0 hdi 150 has a hard night
08.05.2020 21:13 # 1
Sabricivelek
First of all, hello, my vehicle pevgeout partner 2.0 hdi, my car will be comfortable until 150, and then it has been difficult and 3 4 5. 3000 thousand revolutions in the gear did not solve the problem, I did not solve any of my car, I did not burn any car and I did not burn it. I had to press the bottom gas for 3 minutes, he came to the slope when he was going to speed up the car, let it be a bit like a draw and pull something. Sabricivelek 2019-05-01 16:40:36
08.05.2020 21:13 # 2
First of all, between us. Sir, probably the problem with the turbo solenoid valve in your vehicle
08.05.2020 21:13 # 3
makwen
Although there may be many reasons for not exceeding 2800 cycles, I was able to get rid of the same problem with many novice farmer's piles after the egr valve failure. Now, egr valve is chronic, you may not hear it if you go to any outlet because it will want to sell egr. I have been using the tool like this for 3 years by canceling it to an eleltronik master instead of changing it. I had no problems. Until I came to the solution of the problem, I went through 3 masters and spent more money than the solution of the problem, I hope you will reach the shortest and cheapest way.
