Peugeut 307 1.4 HDI Problems .. HELP?
08.05.2020 14:13 # 1
dieselbastard
It is best to write my problems in the form of items and expect answers from friends.
1. Temperature: When you go to a high place, the speed of the car is rising.
Performance 2: I do not expect high performance since my vehicle is 1.4. But the first time I bought the vehicle, their series was serial, now it seems as if he did not want to go. I wonder if the injectors are blocked?
3. Front Teams: If I Have the Front Teams Look At It, Is It Sound Normal Is It Normal Or Am I Exaggerating?
4. Air Conditioning Panel Lights: The Air Conditioning Lights are not lit.If the lamp was cut off now, I don't know why my fuse was blown.
5.When I go on the normal road, I hear a thin noise coming from the wheels of the vehicle as if something is rubbing against the disks.
6. Finally Orj. I want to get information about the balata prices .. How much is the workmanship and part price ..
Car Maintenance I Made:
Timing Belt + set
Radiator Belt
Air filter
Diesel fuel filter
Oil filter
Tie Rod End
Oil Changed + Double Up Nano Added.
Labor and part money;
(490TL + 150TL)
I present my thanks for your attention ...
08.05.2020 14:13 # 2
BuRCaK
GREETINGS.
For the heat, I say, look at the circulation or thermostat.
The sound that comes while you are on the road may be because the brake pads are exhausted.
The bulbs of the A / C lights may have burst. The electricians replace the bulbs in the front hub where the frame is removed and the air conditioner lights are located.
Don't take it if they said there is nothing for the front team. If you listen to the car a lot, you cannot leave the industry.
You can either buy the original lining prices from the service or buy yourself from a place that says "these are the original brother" in the industry. they prevent 30-40 lira. They get workmanship like 20 TL.
If there is anything related to performance, computerized fault detection injectors may occur. Watch out for the diesel you bought. I would say buying from the same pump from the same pump other than eurodiesel.
these are what i know. I used 1.4 HDI 307 in time. I haven't been using a diesel car ever since :)
08.05.2020 14:13 # 3
ErolSen
The original front discs for 206 and the press linings are close to 200 TL, including workmanship.
the erols 2010-04-04 18:38:22
08.05.2020 14:13 # 4
dieselbastard
Thank you very much for enlightening me ...
08.05.2020 14:13 # 5
dieselbastard
Is there a price difference between front 2 pads and back pads?
08.05.2020 14:13 # 6
twelve pads trw brand 40 - 60 TL i think
08.05.2020 14:13 # 7
dieselbastard
[QUOTE = EmRaH] Twelve pads trw brand 40 - 60 TL I think [/ QUOTE]
Is the brand of the original pad TRW, is there no difference between my brother back and front?
08.05.2020 14:13 # 8
coyote26
I have 307 1.4 hdi Wimmer RST chiptuning applied 17 '' I use it without any problems with the rim smoothly. It was about 25,000 km.
