Peugeuot 206 Speedometer Stepper Motor
08.05.2020 19:48 # 1
maksum
Hello friends ,
I have a 201 model Peugeuot 206 brand vehicle. Yesterday I took it to the master for oil + filter maintenance. I saw that the speedometer did not work after I got the car. When I took it back to the master, he said that the speedometer on the step motor was broken. He said that the repair will take a long time, if you can find a bounce, it can be installed immediately. In your opinion, where can I find the speedometer stepper motor in the link below. I searched on the internet but couldn't find it.
http://www.mte.net/sites/default/files/other_photos/sep-mot01-ph2-wm.jpg
http://www.mte.net/sites/default/files/photos/sep-mot01-wm.jpg
Thanks.
I max 2016-05-12 09:52:38
08.05.2020 19:48 # 2
firstly welcome. it is hard to find that piece separately as zeros, but you may find it coming out. room auto electrical - you will find it in electronics shops. you can find sales abroad such as ebay at zero.
08.05.2020 19:48 # 3
Cyrus35
The speedometer on my old vehicle I used to work was working intermittently, the repairman said that it was broken and changed the same error again in the day. I am sure it is solid because the problem was not in the engine, we went for free, we changed the engine for 50 TL in Izmir 6th industry.
08.05.2020 19:48 # 4
maksum
Thank you very much for your attention.
@ Cyrus35
Hodja, if you do such a beauty, you will save me from great trouble. I met several masters today, but I couldn't find it. Of course, if you send a counter payment, you will see my job. The master insistently said that it was from him, we will be seeing after changing my truth differently.
I would be very happy if you inform me after checking in the evening.
Thank you so much.
08.05.2020 19:48 # 5
Cyrus35
Dude last night, I looked roughly, everything is there, but I could not find that little illness, I will look again tonight and I will also gather other parts, I will take a photo and put it here. no need to pay crazy figures
08.05.2020 19:48 # 6
maksum
@ Cyrus35
Hodja, thank you very much. If you can not find it, I would be very happy if you helped to clean it.
Thank you so much.
08.05.2020 19:48 # 7
Cyrus35
No problem, my teacher, if you do not leave your home, I will write to you again, I will go to the industry tomorrow, if you give me your pocket, I will send you msg and give you price and product information.
08.05.2020 19:48 # 8
maksum
I sent your cell phone from private
08.05.2020 19:48 # 9
Cyrus35
I saved your brother number
08.05.2020 19:48 # 10
FLeCh
Hello, I came across this topic while browsing the net. Can you find more from this stepper motor? : / speed indicator does not work, goes up and down it works according to your head it does not work
08.05.2020 19:48 # 11
pomad
Hello friends, do we have a chance to obtain from the stepper motor or can you write the type of the motor with the full name?
08.05.2020 19:48 # 12
Zafer adana
I have the same problem as I continue on the road, the km dial drops, even when the traffic stops and when it gets up, it shifts in the first gear when it pulls up to the 2nd gear.
I noticed that it burns too much.
08.05.2020 19:48 # 13
Hodja does not have a serial code, you can find it on ebay and auto electronics.
http://www.ebay.de/itm/1x-schrittmotor-stepper-motor-fur-jaeger-tacho-drehzahlmesser-peugeot-206-806-/121644925615?hash=item1c529a42af:g:yg8aaoswg3fuqhs to
08.05.2020 19:48 # 14
IsmailK
[QUOTE = Victory adana] I have the same problem as I continue on the road, the km dial drops even when I stop in heavy traffic, I get shaking in the vehicle when I get up to 2nd gear, this problem has happened in the fuel
I noticed that it burns too much. The vehicle gets heavier as it continues with the handbrake applied [/ QUOTE]
I have the same problem with my teacher. On the way to the road, when the speed indicator starts to work at 0, the car gets heavy and it feels like the load is on the car. When the km is normal and suddenly it drops to 0, the car starts to go like a dog.
08.05.2020 19:48 # 15
Selox
Just doing it from the stepper motor also does it from the km speed sensor. ? Zafer Adana is probably your problem. It will definitely look at it without confusing your head. Ismail is just like you ... Selox 2016-11-24 10:33:16
08.05.2020 19:48 # 16
Valdet
I asked in Bursa to show tachometer and speed. stepper motors 2 pieces will change 300 TL bargain request etc. Our friend from Izmir fell to 250. Please write telfnu of the kmc in the industry please
08.05.2020 19:48 # 17
ilhanozgur
In my Peugeot 206, the tachometer shows 10 rpm missing. In a nutshell, the indicator stops at 0, while it should stop in the range of 9-10, then it rises, but while it should show 20, the tachometer shows 10. ilhanozg is 2017-08-14 13:46:56
08.05.2020 19:48 # 18
most likely there was stripping in gears. you have to disassemble and look at the indicator
08.05.2020 19:48 # 19
ilhanozgur
If the gear was stripped, wouldn't it be a problem in his work? It is running smoothly. There is no jumping. Normal rising indicator. The only problem is 20.
08.05.2020 19:48 # 20
Well, brother, it is hard to tell him without looking at the indicator.
Page : / 2
