Peugeout 307 syst antipole defender failure. |
| 08.05.2020 20:31 | # 1 |
| 08.05.2020 20:31 | # 2 |
ALLEX |
Teacher, when you get fuel from a different place than you always get, this kind of error code can be given. Sometimes if there is water in the fuel and this water came to the fuel filter, the sensor gives this error warning about the fuel. Manage this fuel until it consumes and replace the fuel filter. Connect the vehicle to the computer and delete the error code. I believe that it will malfunction. Do not use a fuel additive. I hope you will solve the problem as soon as possible and share information under this title. |
| 08.05.2020 20:31 | # 3 |
ggitaristt |
It happened to me .. When I rooted the gas before the engine exceeded 70 degrees, it would not fail and would not exceed 3000 rpm. There was no problem when the engine warmed up. There could be many reasons. I was connected to the car with Elm 327. The turbocharger pressure sensor cables appeared open circuit. I removed the phone and then I deleted the malfunction .. It didn't fail again .. It is a simple thing for you to get a definite past .. |
| 08.05.2020 20:31 | # 4 |
[QUOTE = ALLEX] My teacher always gives this error code when you get fuel from a different place than you get. Manage this fuel until consumed and replace the fuel filter. Connect the car to the computer and delete the error code. When the car is gaseous and the temperature exceeds 60, everything returns to normal. It sounds like a sensor or cable fault to me. |
| 08.05.2020 20:31 | # 5 |
[QUOTE = ggitaristt] happened to me .. When I rooted the gas before the engine exceeded 70 degrees, it would not fail and would not exceed 3000 rpm. There was no problem when the engine warmed up. There could be many reasons. I was connected to the car with Elm 327. The turbocharger pressure sensor cables appeared open circuit. I removed the phone and then I deleted the malfunction .. It didn't fail again .. It is a simple thing for you to get a definite past .. [/ QUOTE] I just ordered from that device. |
| 08.05.2020 20:31 | # 6 |
The coil cable is chassis. Thanks to the master states in Tekirdağ |
| 08.05.2020 20:31 | # 7 |
Eyvalaah. |
| 08.05.2020 20:31 | # 8 |
ALLEX |
Let it be over and not to worry about Allah.
| 08.05.2020 20:31 | # 9 |
It has started in my vehicle now, can anyone write what is the source of this problem and what is the solution?
| 24.06.2020 00:20 | # 10 |
Currently, my vehicle has the same malfunction. And the engine picture appears on the screen.
| 06.06.2021 18:28 | # 11 |
I had the same problem on 03.06.2021. My car is peugeot 307 hdi 2006 model. I hit the gas a few times after starting the car. Then it gave this error and the car fell out of traction. I took it to the mechanic, they connected it to the device and they changed the heating relay, the error was fixed. By the way, for peugeot, nurani auto in Diyarbakır is really good
| 18.06.2021 22:05 | # 12 |
If the vehicle does not light the antipoll default fault, there is a problem with that vehicle :D almost all 307s have the same problem, sir, if you press the gas a little and clean the fuel, the problem will disappear.
