Peugeout 307 gets armpit-antifreeze |
| 08.05.2020 17:02 | # 1 |
We recently changed the complete water of my Peugeout 307 car, put mixed water with antifreeze. After a few days, when I removed the mat under the driver's seat, I noticed that the gold was getting wet completely and I saw that the water was extremely low. where could this vehicle be losing so much water? previously there was a water reduction, but a small amount, after complete replacement with antifreeze + water, there was excessive reduction. There is no leaking water in a visible place. I would be glad if you could help. & nbsp; |
| 08.05.2020 17:02 | # 2 |
There are kacak in the heating pipes, under the room's chest, you can put the feet ventilation & nbsp;
| 08.05.2020 17:02 | # 3 |
It can also be from the heater core.
| 08.05.2020 17:02 | # 4 |
I do not know how it is from the heater core 307 but in 206's it is necessary to disassemble the torpedo to change it
| 08.05.2020 17:02 | # 5 |
tellotello |
As friends say, he may be kidnapping from the heater core. The reason why the antifreeze + water postponement has increased may be; Antifreeze not only reduces the freezing point of the water (it also increases the boiling point), it also keeps the system clean, that is, it prevents the corrosion in the system or something. Was there antifreeze in your previous water? If it does not, when the system supplies antifreeze water, the dissolution has increased and the area around the avoidance has been cleared so that our friend has found a wider way to flow to him (I think). In this article; If there is a getaway in the style we said, if you would like to see how it was corrected, our friends shared it very well. I hope you can easily handle your problem. & Nbsp;
