peugeot206xr air conditioner problem
08.05.2020 15:16 # 1
furkanbaki
Greetings friends last week, I bought the 2000 model 206xr model, I trusted the friend, I did not look at the air conditioner, brother gas, try new open, I did not try today, I opened it, the ac key leti is burning but it does not say that you are my ban, neither does it contract, it does not cool.
08.05.2020 15:16 # 2
insomnia
run to a place that understands the correct air conditioner
08.05.2020 15:16 # 3
Check if the compressor is activated first.
08.05.2020 15:16 # 4
MemoTech
After pressing the A / C button, you bring the air levels to a position like 1-2-3 and bring them to the blue strip in the heat, right?
08.05.2020 15:16 # 5
ULAS
If the air conditioner gas is missing, the compressor does not start. I had the same problem.
08.05.2020 15:16 # 6
serkan24577
It happened to me before my brother, the reason why the compressor does not start up is because the air conditioner gas is empty due to the absence of air conditioner gas, the compressor was not activated, there was a leak in the gas hose, so it was not a self-discharged problem.
08.05.2020 15:16 # 7
axi206
yes, i had the same problem i got it regardless of air conditioner Money was 200 lira. The hose was leaking gas from the bottom and the top.
Replacing the hose emits a heat.
08.05.2020 15:16 # 8
furkanbaki
thank you so much friends i will take it to a air conditioner as soon as i share the result again
08.05.2020 15:16 # 9
furkanbaki
Yes, my master had 206 before, he did exactly what he said, blowing normal air
08.05.2020 15:16 # 10
murat222
new gas pressed, leak test done, no leak. but the air conditioner is not activated help please .... Dead
08.05.2020 15:16 # 11
suppor
Mine is not working, the radio is melted, chilled, changed, 200 workmanship, 50, 50, 50, 300 good works (there is a leg, but it is not seen where it is made, it is like the doctrines of SSK)
08.05.2020 15:16 # 12
madblueblacksea
[QUOTE = murat222] new gas pressed leak test done no leak. but air conditioner does not work help please .... "Dead" [/ QUOTE]
may be due to gas pressing with gas. The pressure sensor may be faulty. The compressor coil may be faulty. You need to check them. Meslea pressed 600gr gas into my air conditioner and it works smoothly. (It works well at 400gr)
