Peugeot XR Not Working |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 16:52 | # 1 |
| 08.05.2020 16:52 | # 2 |
xpyhre |
The battery can also be a problem. Try reinforcing. There is a high probability of the coil or ignition, there is a problem in the brain. & Nbsp;
| 08.05.2020 16:52 | # 3 |
He stopped, he didn't work, I didn't know what, my friend.
| 08.05.2020 16:52 | # 4 |
aopena |
You can not find a solution here, no one can access you because of this, open the topic under the title of malfunctions and solutions. ;) By the way, the battery is weak and it is most likely that the dynamo vs test be done.
| 08.05.2020 16:52 | # 5 |
I think the problem may be caused by the battery, but it may be due to the brain & nbsp; stopping suddenly while on the road.
| 08.05.2020 16:52 | # 6 |
Did you look at the hood, did the belt stay in place & nbsp; |
| 08.05.2020 16:52 | # 7 |
can be from battery. The same problem could be with the gasoline filter. I had 206 cars in my car, there was electricity but it was not working. There is a filter cover under the back seat. There might be a problem with the cables. the starter can be on the dynamo .. the battery may not be charging itself, which happened to me, stopped while on the road. & nbsp;
