Peugeot Urban Temperature Problem Solution
08.05.2020 18:40 # 1
mhgorgulu
Friends Peugeot 307 brand vehicle was in the city, although the oil and water level in the city was at a normal level, it was overheating (the pointer is ending) and the engine malfunction lamp was on. I saw that this happened to many peugeot owners but the problem was not solved on the internet.
As a result of my consulting with an industrialist friend, the Peugeot expert said that there is a Fan Resistance failure intensely (as a result of using the air conditioner on / off). We connected the computer to the first fan and we commanded the second fan to work, the direct resistance has already identified its own fault. In addition, the resistance, which was 800 lira 4-5 months ago, has fallen to 100 liras at the time of heavy demand. If you encounter heat in the city, you should start the air conditioner without stopping the vehicle, do not turn off the engine immediately. Along with the air conditioner, the second fan is activated automatically and reduces the heat. You can then follow the path of the industry Clap
08.05.2020 18:40 # 2
lead38
Beautiful
08.05.2020 18:40 # 3
Atix
Thanks for information Smile
08.05.2020 18:40 # 4
zr`lmn
Thanks
08.05.2020 18:40 # 5
simirnoffredbull
Could you consult your expert friend that problem, mind is superior to mind maybe
I have a 1.5 comfort peugeot 307 2006 model car. The idling speed in my car falls below what it should be, and when it falls, it gives this error. In general, when the gear shifts down, the speed drops to under 6 when it is below 10 and it gives the error. It does not, and there is no shortage or malfunction in the vehicle. is it doing it because the oil gets thinner?
