peugeot radiator
01.11.2021 17:26 # 1
karasim
hello friends
Peugeot partner 1.9 2002 my car without air conditioning does not blow the heater fan, the car is warming up, but the fan does not work, what could be the reason? There is no electricity in the electric cable coming to the fan motor, I guess I did not have a voltage meter, so I checked it with a control pen. Thanks in advance for your information
01.11.2021 17:46 # 2
flyturk
check the fuse box,
1,2,3 depend on the resistor, test whether it works at the 4th stage. (resistance may be defective)
check the sockets coming to the fan motor (in vehicles such as peugeot, citroen, the socket usually melts and makes no contact)
01.11.2021 18:27 # 3
karasim
thanks for your answer
I couldn't find which one belongs to it in the fuse box, I replaced the f 16 on the front panel with another one, but it didn't work, it might not be
4. It doesn't work at the level either
I saw a single socket coming to the fan motor, the room looked solid, I played a little while it was running, but it changed, thanks for the information
01.11.2021 18:54 # 4
flyturk
You're welcome
If you have a 12v wired control pen, quickly remove all fuses. check it, examine your car's fuse box from Google Images, if the fan's socket is accessible, remove it and hold the + and - of the control pen to the socket and see if there is electricity, if it does, there is a problem in the engine, if not, check the fuse box, resistance, wiring and button
01.11.2021 19:11 # 5
karasim
thanks i will try what you said
01.11.2021 20:12 # 6
karasim
https://i.hizliresim.com/i6ct3ka.jpg
I took this at the driver's place
I'm still not sure which one it is, I think the mechanic's path is visible
