peugeot planet 2000 ecu error
08.05.2020 20:36 # 1
husem
hello I don't know if it is based on vmware. can you help me ?
08.05.2020 20:36 # 2
maximusti
Did you give the diagnostic device access to the virtual machine in vmware?
do you appear in the computer's device manager?
08.05.2020 20:36 # 3
husem
yes it seems it is already reading the chassis number from the vehicle, it shows km information, etc. I will format it and install it on laptoba.
08.05.2020 20:36 # 4
husem
I guess there is a problem with the cable I tried to find another cable (original) exceeded this part though the room gave another error like PP2000 unsupported parameter was sent. but he saw the medicine.
I did not know if I had trouble with the planetary installation or the firmware of the cable.
The planet does not setup directly from the setup. It turns on and off. There is another exe in it. Is it correct to run it after running it?
08.05.2020 20:36 # 5
maximusti
each clon cable has version ranges supported, if you are installing a higher version than that range, it might not work.
Apart from that, when you run many setup files, it first extracts, that is, it extracts the actual setup files to a directory, and then starts the installation.
08.05.2020 20:36 # 6
husem
I changed my cable and installed pp2000 version 25. new cable full chip but i got another error.
OPR No 10592 81 2 0296
08.05.2020 20:36 # 7
KILIC
I wonder if you tried to update or do anything while connected to the Internet. format the computer and say so
08.05.2020 20:36 # 8
husem
I just installed the pc, made a manual update, that is, I updated it with the cd inside. I did not do it on the internet, but I do not know if it did it automatically.
08.05.2020 20:36 # 9
KILIC
Did you make the update when the internet was on? If you did it when the internet was on, it could be from it
08.05.2020 20:36 # 10
husem
It worked flawlessly on my friend's peugeot 307, I probably choose something wrong either dam code or brain but I tried all the brains listed.
08.05.2020 20:36 # 11
KILIC
If it is working on another vehicle, you may be right, you may be choosing something wrong.
08.05.2020 20:36 # 12
husem
There is nothing wrong to choose, I actually open the program, choose 206, ask the code of the dam, I write the first 5 digits 10592 of the door. then my chassis information is coming identification processes then test by ecu (test with electronic control unit) then engine / transmission then diesel
there are brain codes on the chassis, it says 8hz on the chassis, I looked at the engine part, EDC16C3 is written.
08.05.2020 20:36 # 13
husem
I noticed something new, the code written on the brain of my vehicle EDC16C34 PP2000 The codes listed in the list are EDC16C3 so pp2000 may be giving unknown reference error. My friend's tool 307 and EDC16C3 on the brain were connected without problems.
08.05.2020 20:36 # 14
husem
I have done a lot of experiments and when I showed my car as c3 on lexia, it detected EDC16C34 and read the brain. Now I want help on how to activate cruise control via lexia.
