Peugeot Partner Tepe 2017 fault code p0997
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
04.02.2022 07:27 # 1
emresahin55
Hello,
When I connect my Partner Tepe 2017 vehicle to the computer, the p0997 fault appears and is not deleted. No problem was found, the malfunction I mentioned appears, if anyone knows, I would appreciate it if anyone could help
P0997 - SHIFT SHIFT SOLENOI "F" CONTROL CIRCUIT INTERMITTENT / IRREGULAR / PERFORMANCE
17.08.2022 20:19 # 2
ulas55
My friend has the same problem, my vehicle is the same model, when I suddenly press the current gas or pull its foot, the car starts and hits as if it crashes.
17.08.2022 21:19 # 3
emresahin55
I had the gearbox opened 3 times, they couldn't find the problem, keep the axles, the walking changed all the evenings, the problem was still going on.
18.08.2022 17:33 # 4
ulas55
My friend, of course you did it, it's not easy, these things are not easy, I will not worry about the expense anymore. The issue is that the vehicles are young and the km is low, I have been dealing with it since the day I bought it. I spent money, the result was empty, now I use it like that
18.08.2022 17:35 # 5
ulas55
By the way, I had the vehicle connected to the device today, no malfunction records or anything else came out 🤨 🤨 🤨 🤔 🤔 🤔
