peugeot partner doing adventure shooting
08.05.2020 16:32 # 1
M@mitek
slm friends i bought a new peugeot partner adventure 2.0 hdi 2007 model but i have a problem
doing direkson filming on turns it is due to what it is ..
08.05.2020 16:32 # 2
06OzGuR06
First of all, welcome. "Smile" We would appreciate if you introduce yourself by opening a new topic in the link below.
http: //forum.peugeotturkey.com/forum_topics.asp?FID=22&title=yeler%DDm%DDz%DD-taniyalim
If you explain your problem more clearly, our friends will help you.
08.05.2020 16:32 # 3
yavuz25
[QUOTE = M @ mitek] slm friends I bought a new peugeot partner adventure 2.0 HDI 2007 model but I have a problem. Check the tie rods, check the tires and tires and renew them if necessary. Also, you should introduce yourself as my free brother said. "Wink"
08.05.2020 16:32 # 4
06OzGuR06
it is caused by pulling the direkson on turns .. it is due to the rot balasci did not recover again
What kind of pull does it pull when it comes to pulling? The usual situation in front-wheel drive vehicles. There is also a reinforced traction system in Adventure, suddenly accelerating & nbsp; If you press the steering wheel may react adversely. That's why & nbsp; On front-wheel drive vehicles, the gas is not suddenly pressed. "Smile"
08.05.2020 16:32 # 5
yavuz25
[QUOTE = 06ÖZGÜR06] [QUOTE = M @ mitek] slm friends I bought a new peugeot partner adventure 2.0 HDI 2007 model but I have a problem
direkson pulls in turns, it is due to what it is .. QUOTE]
there may be problems in the table and balls, brother.
08.05.2020 16:32 # 6
yavuz25
Let me write it in mind. Never park the helix front wheel on the sidewalk when parking the lifting edges. Be very careful. "Wink"
08.05.2020 16:32 # 7
06OzGuR06
You are talking about hubs when you say table?
There is reinforced traction in adventures, low gears than others & nbsp; more impulsive. "Smile" So
sometimes the steering can react backwards due to traction when suddenly loaded on the throttle. . Member
08.05.2020 16:32 # 8
yavuz25
[QUOTE = 06ÖZGüR06] You are talking about hubs when you say the table?
There is reinforced traction in the adventures of low gears & nbsp; more impulsive. "Smile" So
yes brother.When we park, we hit the tire on the pavement, then the car's head is broken.
