peugeot partner 2015 model display key indicator
01.12.2020 11:37 # 1
ramazansms65
On my Peugeot Partner 2015 model vehicle, the key indicator started to light on the screen. When I turn off the ignition and count down from 10, it lights up again in a minute, although I reset it. I think this indicator failure may occur after the screen tape is installed and the can bus module is installed. or could there be some other reason? How can I delete the switch icon on the screen.
01.12.2020 12:18 # 2
My teacher, connect a pc and check the fault codes, I say only the screen tape does not cause this type of trouble.
01.12.2020 21:04 # 3
ramazansms65
As I guessed, the can bus module attached to the screen tape was detected to be problematic. This was the reason for the key failure.
02.12.2020 14:40 # 4
[QUOTE = ramazansms65] As I guessed, the canbus module attached to the screen tape was found to be troublesome. This is the key failure reason [/ QUOTE].
02.12.2020 14:40 # 5
