Peugeot Partner 1.9 2002
08.05.2020 21:26 # 1
Meyildi
I own a Peugeot Partner 1.9 2002 model car. I have been struggling with a problem for 1-2 months.
The problem is this: 1. I press the starter, a weak working noise stops and stops.
When I start the 2nd starter, the engine starts, (if I press the throttle) then the idle speed indicator does not remain constant. One is rising and one is falling. While walking, he suddenly presses the gas and returns to normal, he does this 3-4 times. I took it to the industry, he said he was kidnapping back to the pump, took 100 liras and repaired it. He did the same again, took me again, he said that the pump is doing air this time, took 100 liras and repaired it again . The problem continues again. What's the solution?
08.05.2020 21:26 # 2
When was the diesel filter last? In addition to the condition of your injectors, the air flow meter can be troubled.
