peugeot misfire when accelerating
09.04.2022 11:37 # 1
Emrah2112
Hello,
While my vehicle is in 1st gear, it keeps shaking it like this in 20-25 band, 40 band after throwing 2, 60 band after 3 throwing. Also, the speed changes as if the engine is going to stop at idle. LPG service was just done in my vehicle and the throttle was just cleaned.
While examining the engine, I noticed that when I press on the manifold, the idle fluctuation goes away. I suspect the engine is getting air.
Can you help?
11.04.2022 17:11 # 2
Change the manifold gaskets bro. If the speed changes slowly around the manifold, it means there is a problem. Like you said, it's getting air.
11.04.2022 18:23 # 3
Emrah2112
Thanks. I will show it to the master but before that I will try what you said.
