Peugeot / Misfire Problem - Chronic
04.03.2022 13:06 # 1
erryann1907
Hello,
I am facing the problem that I have been experiencing for 2 months since I have been disturbed by my 2011 model 92k 308 1.6 VTI engine car, I would like your help..
When going in high gear under 2000rpm, it stutters when I load the gas accelerating. usually between 1700 and 2100 when the vehicle is trying to collect itself.
initial march and idle, from time to time i am doing daily use like there is no problem..
When it exceeds 2000 rpm, there is no problem in acceleration.
The ENGINE FAULT lamp warning is on by itself, as if the path is cleared, when you travel 5 km in 2nd gear at high speed, the next in work SOMETIMES icon goes ..
Is there a problem with spark plug ignition?
Catalyst failure ?
could be caused by coils or spark plugs ?
gas injector ?
It gives "CAM SHAFT ERROR" in computer control, but I haven't been able to solve the situation.
I had maintenance done with original products and castrol oil 15 days ago, what would your recommendations be? .
04.03.2022 17:50 # 2
Hi, first of all, I would recommend you to change the spark plugs. Can you post the error codes as well? Which side do you live in Ankara, if you are close to Xinjiang, I can take a look.
04.03.2022 18:07 # 3
erryann1907
First of all, thank you for your answer. Smile" title="Smile" />
error code given :
P0013 - CAMSHAFT EXHAUST SOLENOID
- OPEN CIRCUIT
- CONTINUOUS
P000B - EXHAUST CAMSHAFT POSITION ACTUATOR SOLENOID VALVE
- Intermittent
/div>
As I said, it doesn't do it all the time.
I'm getting SHELL VPOWER all the time. When this happened, I passed OPET, it seems to have improved, now it's started again..
The engine fault lamp is on from time to time, and I feel uncomfortable with this situation. .
04.03.2022 18:14 # 4
Your problem is probably caused by the electrovalves. But in vti engines, spark plugs are very important, but I would definitely change it every 2 maintenance. solenoid valve is also called excessive contamination etc. if there is, he does it too. You need to clean it with brake lining spray. Don't use castrol bro, it doesn't work for this car. Choose a 5w30 quality oil.
14.07.2025 17:20 # 5
Rock
Did you solve the problem? I have the same problem with 207 1.4 vti.
