peugeot lpg compatible
08.05.2020 16:48 # 1
tolqaxde
What is the compatibility of peugeot vehicles 308 and 207 lpg?
08.05.2020 16:48 # 2
mustafacan
I don't think it will be a problem. BRC, Landi these are not problems.
08.05.2020 16:48 # 3
asbircan
think of bikez again :-) or meet your master very well because now your path will drop a lot, huh there is a fact, you save 35%. After having it done very well while having it done, the rest is just enough to get rid of the false supports 0.
08.05.2020 16:48 # 4
mustafah
event looks at the master & nbsp; "Smile" & nbsp; BRC, Landi Renzo quality brands, but the master who installed it properly is the most important & nbsp; < img src = "smileys / smiley4.gif" border = "0" alt = "Big smile" title = "Big smile" />
08.05.2020 16:48 # 5
impact
I am using landirenzo evo. It has been 1 month, though I did not have any trouble with the other car (vectra c) I have zavoli, I had no problems with it, but zavoli cuts LPG when it passes a certain cycle, landi also has no problem such that it can throw LPG up to 8000 cycles.
The only problem I had was the fact that the gas tank was empty, which was a problem with the French vehicles.
08.05.2020 16:48 # 6
kirmizi306
My friend's 308 had an agitator, it didn't have a problem. But you have to have a kit installed. Even if you fill the gas tank full, it shows nothing.
There is only one fact, no car of Peugeot likes Lpg.
I know that lpg peugeot with prins lubrication system is problem-free, but they are more expensive than normal. >
08.05.2020 16:48 # 7
gaspart33
hello friends 208 1.2 vti I had my atiker grand kit with my motor vehicle there is no problem now, there was no performance loss event, I did not feel it but there is a gas gauge problem, when i go to buy lpg, the indicator is improved when i get 20 TL gasoline, my fuel consumption is around 40% petrol lpg difference the situation of the road and I only saw the obvious difference in the city, this work would be smooth if it was a very well assembled place. A 130 kW regulator and roman injectors for a motor are feeding the car sufficiently about lpg. people sure do not forget that this job is 70% assembly & nbsp;
08.05.2020 16:48 # 8
ersinyildiz
[QUOTE = gaspart33] hello friends 208 1.2 vti I got my atiker grand kit on my motor vehicle no problem right now there was no performance loss event, I did not feel it, but there is a gas gauge problem, when i go to buy lpg, the indicator is improved when i get 20 TL gasoline, my fuel consumption is 40% as of now There is a difference of petrol lpg around the road and I only saw the obvious difference in the city. This work is very good if it is a well assembled place. My financial power is not enough for brc or prins. A 130 kW regulator and roman injectors for a motor are feeding the car sufficiently about lpg. people are sure that this is 70% assembly & nbsp; [/ QUOTE]
is not relevant, but if you keep your gas level above half a tank, the indicator refreshes itself without the need to refuel. Like in 206. I guess it is no different in 208. & nbsp;
08.05.2020 16:48 # 9
Karacocuk24
Good road computer, my 206 has no problem with the hand because of it
08.05.2020 16:48 # 10
gaspart33
I have never been on half a tank but I will try your advice & nbsp;
