peugeot Fuel pump not getting power
04.04.2022 20:44 # 1
lajque
I use Peugeot 206 petrol & LPG when the vehicle is parked, it does not start, but the fuel does not activate, I also try LPG, it definitely cuts off the fuel, the auto electrician tried a new fuse plate, it did not work, it was not a fuse, it does not connect to the ECU because it does not see the brain, what could be the problem?
06.04.2022 21:55 # 2
talip206
Which fuse plate was changed inside? Is that in the engine compartment.
Generally, the fuse plate in the engine compartment causes this fault. There is a relay that triggers the fuel, its foot is cold soldered or it burns. A good electronics solves it, but they don't bother and replace it with a new or removable fuse board.
