peugeot economy mode
08.05.2020 14:11 # 1
ugur
hi friends, our peugeot vehicles switch to economy mode 30 minutes after stopping the vehicle, and no electrical parts are working, it is necessary to start the vehicle even to open the pines. it is impossible to listen to music and open and close the windows without trying the tool at least it would be nice if this is due to the contact. Is it possible to cancel this? If you can not sit in the car with pleasure on the beach, anyone who wants to enjoy your car understands whether it is possible to cancel or disable me.
my car peugeot 307 hdi.
08.05.2020 14:11 # 2
kocvizyon
bro, if you cancel it, it will damage your vehicle especially
08.05.2020 14:11 # 3
F-Eren
I think it's a good thing to call it canceling economy mode
08.05.2020 14:11 # 4
ErkanKurnaz
I guess you can't cancel because bsi controls the economy mode
08.05.2020 14:11 # 5
hasimayaz
Maybe someone with electronic knowledge at the engineering level can do it, but it is likely that it will remain in your hand. The time may be extended from Rom dumps.
08.05.2020 14:11 # 6
BuRCaK
economy mode disables the components that consume a lot of energy from the battery without causing the car's battery to run out. This allows you to start the car again. In other words, when you are chatting on the beach, it is made to prevent you from saying "noluyo len to this car" when the music is interrupted by not understanding how time passes. Sırıtma If it did not prevent this, you would have solved the situation with the battery jumpers and started the car. Since such systems work with BSI, they cause a small BSI error to burn. The solution is to either repair (you cannot get the original efficiency) or replace it. Neither of them psychologically tastes old in your feelings for the car Gülme
When I had 307 HDI, I had to go to a jealous PRIVATE VOLVO service in Bostancı industry. I stayed in the industry because my starter motor burned. soon he had to the shop. They could not start the vehicle and accidentally touched the brain against the pole. Sinirli the result is burned, of course ...
whatever he did, he could not work. Göztepe has Beyinci Nuri in the industry. Yes, the car worked, but it never enjoyed me. Then when I had problems with the turbo, I had it repaired and sold. You cause big trouble per touch to the veins going from the story to the brain Kahkaha
08.05.2020 14:11 # 7
pendikpeugeotservis
my friend mrb economic mod has no cancellation
08.05.2020 14:11 # 8
I guess the subject is hosed :))
