Peugeot Cruise Control Malfunction Solution
08.05.2020 21:09 # 1
iso0625
Friends priorities good forums. I'm new to the forum and you're the first. Despite the fact that my Peugeot 407 1.6 hdi was not working in my original cruise control. When I wanted to activate the lines on the screen were blinking, I solved my own problem by trial and error. Clutch or brake can be attempted before replacing the sensor. The Lexia 3 device is of course necessary. Apply in order. After connecting to the vehicle with the device, we first select our vehicle and open the diagbox program respectively After selecting Repair> Engine control calculator> Repair> Tele coding> Manual tele coding> Tele coding> Remote coding of control device> Vehicle speed limitation> Yes , we click the action button and coding is done. Note: If the vehicle speed limiter is already in the current position, first select it as none, press the action button and code it, then select it as there and complete the coding by pressing the action button. I hope that I got the solution in this way, it is useful.
08.05.2020 21:09 # 2
Sahinkirac
first of all hello i have 206+ model my screen is broken when the cruise control is activated
08.05.2020 21:09 # 3
iso0625
Hello, I have to connect to the device and see if there is a malfunction.
08.05.2020 21:09 # 4
burhanakbas
Hello friends, If you are going to get the paugeot 508 semi-automatic etg 6, let's watch the video below first and talk about the pros and cons. C5 citroen, Passat, jetta, astra, insignia, corolla, focus, superb, octavia would be good to watch; https://www.youtube.com/watch?v=o_05yfoaham&list=uuagskmipsu3t7oz_agx-mta&index=2
Peugeot Forums - Peugeot Fan Club © 2025
