peugeot clutch pedal vibration
30.03.2022 21:04 # 1
Hybris06
Hello, I feel something like a vibration in the pedal when I press the clutch and lift it after 3000 rpm in my 2016 Euro 5 partner Tepee vehicle. There is no problem with the clutch, the only problem seems to be that the pedal vibrates at high rpm. What do you think is the problem? Thank you for your comments in advance.
01.04.2022 14:38 # 2
Have you checked the transmission mounts, sir? There is a vibration in the vehicle. These types of problems can usually be caused by wedges. I would suggest you to look at the axles.
