peugeot car stalls
12.04.2022 22:30 # 1
jackal300
https://www.hizliresim.com/ceillf0
error codes appear in the picture
could it be crank sensor or map sensor
to vehicle I start it, it stops 4 I tried 5 times, I tried it directly on LPG, I tried it on the same gas, I give the same gas and try, it stops again
Vehicle peugeot 206 sedan 1.4 comfort 8valf 2009 model petrol lpg
14.04.2022 09:01 # 2
First of all, go to a good master. Let the vehicle look at the timing belt and make the valve adjustment. The oxygen sensor is faulty, as you said, the crank sensor is probably faulty. You can have more precise information with the original software. They are good about mass peugeot var 206 in ivedik.
16.04.2022 09:50 # 3
jackal300
Thanks for the comments, I installed the obd device and looked at the error codes again, the injector 4 error came, the 4th gasoline injector was changed in the industry, the problem was fixed, thanks
18.04.2022 09:32 # 4
I'm glad the problem is fixed.
